Boost pipes n dump valve
Old Feb 21, 2006 | 12:04 PM
Paul17's Avatar
Paul17
Default Boost pipes n dump valve
I've just change my boost pipes on my series1, before the dump valve was t-peiced into the boost pipe that links the charge carrier to the intercooler usual place, now i've got another charge carrier that has a dumpvalve union welded on to it so now the dump valve is on the other side. dose any one know of any pros and con's for having the dumpvalve on this side? thanks
Old Feb 21, 2006 | 04:53 PM
Oranoco's Avatar
Oranoco
Pro's none
cons none
Best option - Bin the DV and blank off the resulting hole
Old Feb 21, 2006 | 06:14 PM
Paul17's Avatar
Paul17
Thing is since i've done it it keeps cutting out when i start from cold. it starts up then just cuts out stright away until it warms or u rev it hard for a bit think i might of knocked a wire or summat when i've the boost pipes?
steve.rst
Mar 15, 2016 08:01 AM
Chas
Oct 5, 2015 07:13 PM
rs_jim
Sep 19, 2015 08:41 PM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
markk
Sep 9, 2015 08:11 AM
