What the biggest
Old Feb 20, 2006 | 09:16 PM
thelynx's Avatar
thelynx
Default What the biggest
Hey
Whats the biggest brake set up you can have behind standard 15'' wheels...
I need decent enough stoppers, when my zetec turbo is finished..
Not looking to spend £500-£600
looking for £250-£300 to spend.....
Ive heard that 2wd drive cossie disks and standard calipers are good? Any suggestions?
Cheers people
Old Feb 20, 2006 | 09:26 PM
DazC's Avatar
DazC
I found that 283mm discs were the biggest you could get behind the standard 15" wheel. You may be able to get 300mm discs behind a motorsport 15" wheel though...
Old Feb 20, 2006 | 09:28 PM
T28 RST's Avatar
T28 RST
Ok then
A Cossie set up will give you much better brakes and fit nicely behind your 15s
Old Feb 20, 2006 | 09:33 PM
thelynx's Avatar
thelynx
Is that with the 2wd calipers or the standard escort rs ones?
Old Feb 20, 2006 | 10:06 PM
DazC's Avatar
DazC
That was with modified 4x4 calipers with 1mm shims to space them inwards slightly and 2wd discs.
Old Feb 20, 2006 | 10:29 PM
Davey8oy's Avatar
Davey8oy
i fitted a set of 195 mm bremsport brakes that i got off of a fella on here!
they were about 600 quid and come with alloy bells!
look the tits and stop on a penny!
think it was NUTS RS that gave me the no!
Old Feb 20, 2006 | 10:32 PM
BillyCabrio's Avatar
BillyCabrio
I'm running 2wd discs and the 4x4 callipers with the 1mm spacer washers.
Easy job.
Little money.
A man with no eyes could fit it too
Old Feb 21, 2006 | 06:49 AM
ivorbiggun's Avatar
ivorbiggun
2 w drive disc's plus brackets off Clint Gaskin (turbo sport £40) and keep your S2 calipers/ more power than 4X4 set up as the calipers sit right on the edge of the dics thereby more braking effort/use money saved to buy goodridges and (if you've got it) junk the whole 'abs' system.......then when you've got a bit more dough.
Brackets off Tony Pastie (zetec turbo £40) scorpio calipers and slider brackets off breaker (£25)(or new about £130) new discs Scorpio (£35 any motor factor) new pads (£25) M5 RS2000 handbrake cable (£30) break fluid
(£5/10) + one afternoon = car that stops just like a modern one!
Don't bother with Cos set up on the rear as you'll just keep swapping ends
as you hit anchors.
Old Feb 21, 2006 | 07:36 AM
thelynx's Avatar
thelynx
Old Feb 21, 2006 | 02:55 PM
jezRS's Avatar
jezRS
im pretty sure you could just fit the escort cosworth calipers and discs behind them, with a nice set of green stuff pads that will work so well!
Bailes1992
Sep 19, 2015 02:17 PM
Ben26
Aug 27, 2015 08:56 PM
Shows & Track Days
Aug 15, 2015 06:25 AM
wimwerf
38
Jul 18, 2004 06:02 PM
