gt 35 compressor stall
Old Jul 24, 2004 | 07:44 PM
cossie400's Avatar
cossie400
Default gt 35 compressor stall
a mate of mine had his cossie on the rollers today at engine advantages and made 550bhp@ 28 psi of boost trouble is he was aiming a bit higher but when the boost was uped all you'd get is alot of compresor stall. what would cause this? his spec is gt35, rs500 inlet, 8 greens, 7:2.1 comp, grp a ported head, bd16 inlet and bd14 exhaust cam. the only thing we can think of is the exhaust cam is to small because the air is getting in but can't consume it into the exhaust quick enough causing the turbo to stall? any input would be apprieciated thanks.
Old Jul 24, 2004 | 07:50 PM
weegaz22's Avatar
weegaz22
needing bigger inlet valves? only thing i can think of is the engine cant take in all the air as the valves are too small or cam lift and duration isnt good enough...but im probably wrong
Old Jul 24, 2004 | 08:06 PM
Billabong's Avatar
Billabong
What do EA reckon?
Old Jul 24, 2004 | 08:17 PM
cossie400's Avatar
cossie400
i would not be asking if paul had said anything seems like when you get into this sort of power range tuners seem reluctant to give advice unfortunatly but as far as i know paul did not seem to know, cheers
Old Jul 24, 2004 | 08:22 PM
Rich_w's Avatar
Rich_w
Proven Legendary Status
Question for the un-initited.
What is Compressor stall? Is it that the shaft actually stops or just the power line on the graph just plateauxs at a certain point?
Old Jul 24, 2004 | 08:25 PM
Billabong's Avatar
Billabong
I don't know enough about that level of spec to give any decent advice, but reckon you and the above posting (weegaz) are on the right track, or at least sounds plausible.
Time to speak to some other tuners methinks..... Martin Hadland of Reyland Motorsport (figures/performance stat's speak for theselves, and his prices might surpirse you!) & Harvey@SCS have plenty of experience with this level of tune, or there's Stu@Motorsport Developments, Karl Norris who both use this board.
Incidentally, who spec'd/ mapped / built the engine / decided on turbo?
Good luck getting it sorted.
Old Jul 24, 2004 | 08:38 PM
Alg1k's Avatar
Alg1k
Should have got Karl to do you a proper cyl head
Old Jul 24, 2004 | 09:28 PM
CraigN's Avatar
CraigN
sounds like SURGE to me
look up the essays using the search button
CraigN's Avatar
CraigN
was this dave btw ?
Old Jul 25, 2004 | 09:12 AM
Stavros's Avatar
Stavros
DEYTUKURJERBS
GT35 and Engine Advantages...
I predict a rod will shortly come flying clean out the block...
Old Jul 25, 2004 | 09:15 AM
Jon ERST S2's Avatar
Jon ERST S2
oh dear. They haven't been getting a lot of good press have they recently.
more than happy with my map then thats pretty basic.
Old Jul 25, 2004 | 11:47 AM
Spiky's Avatar
Spiky
again you mean
Old Jul 25, 2004 | 11:51 AM
Stavros's Avatar
Stavros
DEYTUKURJERBS
again you mean
youve lost me now, lol
has cossie400s mates car already thrown a rod?
Old Jul 25, 2004 | 11:54 AM
Spiky's Avatar
Spiky
no but i know a man who has
Old Jul 25, 2004 | 12:03 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
now your talking in riddles
i know of 2 EA cars that both recently pushed nearly 600bhp with GT35s and then not long after decided to put a rod into orbit.
someone REALLY needs to teach EA whats a "good" external wastegate mounting position, and whats a "easy, but wont fookin work" one too
ive lost all faith in em!
Old Jul 25, 2004 | 12:07 PM
cossie400's Avatar
cossie400
no not yet since brendon has left you just dont seem to get the same level of help its get in get out
Old Jul 25, 2004 | 12:30 PM
Jon ERST S2
The other guy has left?
How come?
Old Jul 25, 2004 | 12:33 PM
Phil's Avatar
Phil
Jeebus
Unless its just miss-firing then the problem will be that it can't consume enough air! I'd be doublechecking the head porting to see if it is all it's made out to be!
Old Jul 25, 2004 | 12:37 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
How come?
maybe he realised going from working for a world class company like AER http://www.aerltd.com/ to a poxy tuners doing loads of pretty ordinary roadcars was a downstep, and has gone to beg for his old job back
Old Jul 25, 2004 | 12:39 PM
cossie400's Avatar
cossie400
just wandering how would the position of the wastegate make the engine go tits up?
Old Jul 25, 2004 | 12:43 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
if the wastegate was fitted in such a stupid place it could hardly flow anything, so the boost was going sky high, then thats a problem.
dont think thats why threw a rod tho, jus one of the problems
Old Jul 25, 2004 | 12:45 PM
Kev.H's Avatar
Kev.H
I read a few strange stories about EA now what big power cars have let go ?? is the white wrc wing'd Ractek car still going ????
Old Jul 25, 2004 | 12:47 PM
cossie400's Avatar
cossie400
nope brendon has gone back to newzeland last i heard
Old Jul 25, 2004 | 12:52 PM
Porkie's Avatar
Porkie
Time to speak to Martin or karl if you ask me.... two people who have fitted GT turbos on YB engines and had proven and reliable results.
Look at what Steve says... Coincidence??? NOT in my opinion.
Old Jul 25, 2004 | 12:59 PM
TIFF's Avatar
TIFF
Chasing Radders
hhhhhmmmmmmmmmmmmm, very strange
Old Jul 25, 2004 | 02:34 PM
Billabong's Avatar
Billabong
I forgot Martin in my list
www.reyland.co.uk for his number, you won't be dissapointed......
Old Jul 25, 2004 | 03:45 PM
turbinator's Avatar
turbinator
Default Re: gt 35 compressor stall
well .. i think i can explain the reason .. and also the reason I dont use rollerbearing turbo's above 400 bhp!
the problem is in the design if you ask me, we have tried 5 engines with rollerbearing turbo's for rally purposes (2 cosworth and 3 evo 7 engines)
they all went bang because of the rollerbearings being eaten by the engine, after some research it showed that the axle was giving way when you go off throttle (up and above 2 bar or 28 psi or more)
this seems to wreck the rollerbearing and since going off throttle happens a lot on a rally car the engines never made it to the finish line..
and we quit using them in the rally because we like to make it to the finish line
garett only gives support up to 2.6 bar (1.6 bar absolute)..
which is to low for the rally..
nowadays it seems you can get hybrid ones which should do better but i am not trying anymore
Old Jul 25, 2004 | 03:53 PM
GARETH T's Avatar
GARETH T
dont you mean 2.6 bar absolute, 1.6bar gauge
Old Jul 25, 2004 | 04:00 PM
turbinator's Avatar
turbinator
yes... thats what i meant..
Old Jul 25, 2004 | 04:28 PM
GARETH T's Avatar
GARETH T
Old Jul 25, 2004 | 04:33 PM
wimwerf's Avatar
wimwerf
and 550bhp is still not enough
Old Jul 25, 2004 | 05:56 PM
EA the cossie tuning saviours...................NOT!!
Old Jul 25, 2004 | 09:01 PM
spenner's Avatar
spenner
turbo stall eh thats what happens with an incorrectly specced engines those turbos are good seen 2 on dyno recently produce 600 bhp neither had any stalling problems but engine specs were a lot more up to date and were running on better ecus
Old Jul 25, 2004 | 09:22 PM
Porkie's Avatar
Porkie
Turbinator, Were you running a Dumpvalve on these cars?
Karls, Martins, and my Turbo that did the Gumball have had NO problems at all in the cars....all running over 600bhp reliably. Not heard of any problems with these Turbos at all apart from what YOU have alledged happened. They DO need to be watercooled and run dumpvalves though.
Be interesting as more and more people use these Turbos and I think you will be proved to be very wrong!
Old Jul 25, 2004 | 10:19 PM
Escort_Cos's Avatar
Escort_Cos
no the racetek car is not going anymore. another dead EA engine.
i mentioned this in another post but since we are on the subject again i'll say it again. EA are the worst rip-off tuners i have ever seen
Old Jul 25, 2004 | 10:22 PM
Martin-Hadland's Avatar
Martin-Hadland
1st to 200 without NOS
bill, shame on you, who was the FIRST to fit a Gt35 to a cossy!?
Old Jul 25, 2004 | 10:43 PM
CraigN's Avatar
CraigN
i heard ian from racetek was a bit shocked after his engine let go then the respnse from EA
after spending thousands of pounds with the company
2nd hand wives gossip tho
thats what these forums are all about.
cossie 400
is the car in question daves car ?
Old Jul 25, 2004 | 10:45 PM
GT2's Avatar
GT2
Not much warranty on a tuned car then...?
Old Jul 25, 2004 | 10:46 PM
Martin-Hadland
its nothing to do with valve sizes...
Old Jul 25, 2004 | 10:55 PM
Escort_Cos's Avatar
Escort_Cos
CraigN,
it's not gossip it's fact!
