Sloppy change
Old Feb 19, 2006 | 04:54 PM
Rick's Avatar
Rick
Default Sloppy change
Just a bit of info. If you are buying a quickshift to sort out ur crappy gear change, be aware that it isn't always going to be the cure. There are linkages that wear at the gearbox end, and u only get replacement bits for the acutal gear lever in the kit
Old Feb 19, 2006 | 04:57 PM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
STD linkage bars are naff.
I use a steering colum knuckle, cut off and welded in place of the STD factory knuckle.
Also if you use Puma internals it will be the same as a Quickshift.
Money spent = £15
Old Feb 19, 2006 | 08:07 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
I have seen another piece of info in the last few days about how to improve the S2 linkage and might try that out soon.
Also, B&M is the ONLY way to go IMO for shifters. I have used the Rally Design type set-up and it isn't even close to the feel of the B&M.
Old Feb 19, 2006 | 10:38 PM
Johnny Knoxville's Avatar
Johnny Knoxville
That info your talking about to improve the linkage in on www.Zetecinside.com in the gearbox bit
Old Feb 20, 2006 | 10:26 AM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
Jano_OddKidd, You never cease to amaze
Old Feb 20, 2006 | 01:34 PM
SafeChav's Avatar
SafeChav
Money spent = £15
Are you talking internals in the actual box the gear stick is in? Any more info on how this is done please
Old Feb 20, 2006 | 05:49 PM
Versus_Creations
Ask me a question!
Yes mate, just that...
Take them both apart and have a look for yourself.
Old Feb 20, 2006 | 09:59 PM
SafeChav's Avatar
SafeChav
Are you donating a Puma linkage to a worthy cause then???
Old Feb 20, 2006 | 10:29 PM
BillyCabrio's Avatar
BillyCabrio
Even the RD one must be better than a wooden spoon?
Old Feb 21, 2006 | 11:35 AM
Versus_Creations
Ask me a question!
Load of pumas in essex that are dead. The scrappers here give the linkages away anyways
Old Feb 21, 2006 | 11:36 AM
SafeChav's Avatar
SafeChav
Free u say??? Hint Hint nudge nudge
Nov 1, 2015 06:53 PM
dojj
Sep 29, 2015 10:32 PM
rsguy
44
Sep 29, 2015 03:29 PM
marky_g
Sep 12, 2015 04:26 PM
