Help with Leather please
Feb 19, 2006 | 02:52 PM
The leather on my n/s/f door panel of my Saff has shrunk does anybody know how I can stretch it back to its original shape?
Feb 19, 2006 | 03:09 PM
Mine too, help please
Feb 19, 2006 | 03:34 PM
leather
the car upholster s heat the leather up with steam . ive never tried it but it doesnt harm the leather
Feb 19, 2006 | 08:30 PM
Would a wallpaper stripper produce the sort of steam required for this job?
Feb 19, 2006 | 08:35 PM
Paul
Give Mark Lander a ring, he had the same problem and had his door cards retrimed and they do look lush..
Dave
Feb 20, 2006 | 10:35 AM
steam
yeh it will create the steam > be a bit fiddly wit the size of them though!
Feb 20, 2006 | 04:20 PM
Dave Thanks will try him.
The paper stripper can be used using just the hose so if expensive to get re-trimmed will give that a try.
Feb 20, 2006 | 05:19 PM
Be careful using steam, it can make the problem worse. The glue ford used degrades due to age and moisture, and using steam can make more of the glue fail making the problem worse. It is always the nsf panel that seems to go first. Re-trim is the way to go but cheap it aint.
Feb 20, 2006 | 08:58 PM
Thanks for that advice, looks like re-trim might be the only way. What does not cheap mean?
Feb 20, 2006 | 09:08 PM
cant you try getting hold of a second hand one.probably be cheaper that way?
Feb 21, 2006 | 05:53 PM
Problem there is not many people will split any interior they have. unless anyone knows of any out there.
Feb 21, 2006 | 05:56 PM
Take it off & refit it
Feb 21, 2006 | 08:24 PM
I think mines shrunk so much below the door pocket I cant see that it will stretch back to its original position.
Nov 1, 2015 06:53 PM
stevecfrst1
Sep 30, 2015 05:18 AM
Kam B
Sep 24, 2015 10:40 AM
dave1960
Ford Fiesta
Sep 16, 2015 11:34 PM
