Series 1 miss firing at low revs
anybody got any ideas heres whats been changed
2 sets of plugs
2 sets of leads
dizzy cap
rotor arm
dizzy
absolutley stumped i need help
Its missing slightly on idle then as you rev it up it misses till about 2500revs then goes away , when under load its seems to miss even more , but as soon as you come on boost its fine
ideas?????
2 sets of plugs
2 sets of leads
dizzy cap
rotor arm
dizzy
ideas?????
John, have you checked the cam lobes, compression, valve springs and that all the square rockers are fitted under the rocker arms? (if the car was running fine before and has just started doing it, forget the last bit)
Tiny air leaks can make it sound like its miss-firing, for example, not having your mixture screw blocked on the air box/metering head assembly. The early ones IIRC have a screw in them to block the hole, i experienced this problem on my first RS due to the screw being substituted for a piece of masking tape
engine was taken from my mates car running fine when removed now its in this and missing
metering head is blocked off
and it doesnt just sound like its missing it actually is
Yeah i know what your saying, mine we tried everything to cure what appeared to be a miss fire but after all the expense and changing parts we found the real fault. extremely difficult to tell the 2 apart though if the air leak is tiny.
What parts of the engine and running gear arent from your mates car then. i would elimate the "foreign" parts first
Well.......i know its a real pain in the arse but in such cases you have got to pain stakingly rule out all the posibilities. Quite a few possible ones in this case.
Have you got a vacuum gauge? And have you compression tested the engine since its been in your car?
DixieTheKid
11
Jun 6, 2020 11:20 AM
Bailes1992
Sep 19, 2015 02:17 PM
