Uprated Alternator?
Old Feb 17, 2006 | 07:39 PM
GraphiteGray's Avatar
GraphiteGray
Default Uprated Alternator?
Right this is gonna sound stupid but....
Do RS Turbos have a different alternator to the XR3i, like an uprated one?
If not have any of you fitted an uprated one off another Ford model? ie for better charging etc?
My old alternators just died and im wondering if theres a better one to fit if you know what i mean
Old Feb 17, 2006 | 09:45 PM
HORNETS7's Avatar
HORNETS7
hmmm i'm pretty sure rs turbos have a 70amp alternator as opossed to a xr3i 55 amp one ive been told as well that u can get a 90 amp alternator of a old granada ! 2.9 i think
Old Feb 17, 2006 | 09:49 PM
bassboy's Avatar
bassboy
90amp off a granada which in some cases need the front pully changed
im running a 180amp one in mine
bassboy
Old Feb 18, 2006 | 09:50 AM
gus's Avatar
gus
yep i use to use the one from a granada
Old Feb 18, 2006 | 12:15 PM
addiction's Avatar
addiction
all Fords with heated front screens have a 70 amp alternator.
there was a company on ebay selling 85 amp alternator's for the ERST. they are brand new one's too,not reconditioned one's.
Old Feb 18, 2006 | 07:25 PM
GraphiteGray
Are they the same on all the granadas or should i get one off a higher spec one?
I take it they fit straight on?
Old Feb 18, 2006 | 07:46 PM
Combi_Chris's Avatar
Combi_Chris
bassboy
where did you get your 180 amp alt
Old Feb 18, 2006 | 08:52 PM
Rick's Avatar
Rick
180 amp? That will need twin pulleys surely.
Old Feb 18, 2006 | 08:55 PM
Glen's Avatar
Glen
I used to run a 115amp on my old S2, think it was from a old granada with air con !!!
I did have to change the spacers on the alternator pulley to get it to line up and not squeelllllll !!!
Old Feb 18, 2006 | 10:08 PM
GraphiteGray
i take it the granny alternator plugged straight in, you didnt have to chop the alternator wires about?
Old Feb 19, 2006 | 02:26 PM
SafeChav's Avatar
SafeChav
Have you actually got a need to uprate the alternator?? If your old one has died it will cost you about £20 to make it like new again......unless your running some mental sound system or have 50 transit batteries in the boot it really won't need it (plus bigger alternators create more drag).
Ive got a standard 55amp one on my cabby, and the biggest battery i could fit in the tray and its absoluetly fine.
You'll probably find you will have to mod the wires for the granada alternator too. Just get a new brush/diode pack for yours is what i would do, cheaper aswell.
jonfoc
16
Sep 11, 2018 05:35 PM
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
jay030787
Sep 18, 2015 04:38 PM
