Amal valve
Old Feb 17, 2006 | 04:17 PM
1_robbo's Avatar
1_robbo
Default Amal valve
Hi all,
Bit of advice from you tech guru's please, is it ok to leave the Amal valve disconnected permenantly as this seems to have cured a misfire on high boost. Car is Saff 4x4 stage 3.
And is this normal that it would cure the problem or just coincidental ?
Cheers Mark
Old Feb 17, 2006 | 04:52 PM
OvaBoost's Avatar
OvaBoost
It shouldn't cause the problem i wouldn't of thought so probably coincidental.
and iirc yeh its fine to leave it disconnected
Old Feb 17, 2006 | 08:52 PM
Stu @ M Developments's Avatar
PassionFords Creator
Of course it isnt coincidental, unplugging it has lowered your boost pressure
Getting her fixed properly should be your number 1 priority..
Old Feb 17, 2006 | 09:16 PM
martinmace's Avatar
martinmace
possibly overboosting and set up incorrectly take stu,s advice and get it checked out by a tuner or it could become more than just a misfire
Old Feb 17, 2006 | 09:38 PM
HORNETS7's Avatar
HORNETS7
as above when its connected the ecu opens it to full boost !!
when its disconnected it halfs the boost!
so now your running half the boost u was!
Old Feb 18, 2006 | 03:37 PM
ivorbiggun's Avatar
ivorbiggun
Co-incidence..There ain't no such animal
Old Feb 18, 2006 | 04:24 PM
Old Feb 18, 2006 | 05:28 PM
1_robbo's Avatar
1_robbo
Thanks to all for the replies, so basically i have just bypassed the problem by the sound of it ?
Stuart, i have heard good things of your place and i am in the north west, what would you suggest, a diagnostic check perhaps ?
Maybe i should try to get up to your place in the next couple of weeks for a visit.
Cheers Mark
Alvyn's Avatar
Alvyn
most probably the amal valve HAS got the wrong size jets for the spec your running now!
Old Feb 18, 2006 | 05:31 PM
Book her in for a good setup if she hasnt had one for a while, details of what we personally do in a setup are here:
http://www.motorsport-developments.c...ginetuning.htm
Old Feb 18, 2006 | 06:09 PM
1_robbo's Avatar
1_robbo
Ok Stu thanks, roughly how long would this take as i am always stuck for time due to running the kids to from school etc
Old Feb 18, 2006 | 07:18 PM
General estimate is 4hrs pal.
steve.rst
Mar 15, 2016 08:01 AM
Nov 1, 2015 06:53 PM
DAZZER
Sep 30, 2015 08:43 PM
fordrallycar
Sep 30, 2015 07:57 PM
rs_jim
Sep 19, 2015 08:41 PM
