water feed to/from turbo
Old Feb 16, 2006 | 08:04 PM
Canada1's Avatar
Canada1
Default water feed to/from turbo
I require some information regarding the water cooling feed lines to the T3 turbo. I know that the top radiator hose has a T like connection to the turbo, the other water line I have not seen any pictures of. Where does this connect?
My assumption is it connects to the radiator itself, with a fitting positioned half way up the side tank?
Let me know If this is correct.
Old Feb 16, 2006 | 08:06 PM
Oranoco's Avatar
Oranoco
Sounds right.
The feed comes from the water pipe from the top rad hose (rad to thermostat housing) and the retunr goes straight back to the hot side of the rad
Old Feb 16, 2006 | 08:09 PM
gee1599's Avatar
gee1599
to the rad just above the hose out let on the offside
Old Feb 16, 2006 | 11:09 PM
Combi_Chris's Avatar
Combi_Chris
how many people actually do that ?
Old Feb 16, 2006 | 11:14 PM
zippyobrien's Avatar
zippyobrien
have you got yours disconected then?
was going to do this to see if the car would run a bit cooler, people said to leave it connected up though????
any thoughts as i would rather disconect the fooker
Old Feb 16, 2006 | 11:19 PM
Combi_Chris
mines not connected, temp is usually around the N mark.
whats funny is, im thinking about connecting mine up, LOL
i was advised not to by one person, said that 200 bhp does not warrant that extra cooling............
Old Feb 16, 2006 | 11:37 PM
zippyobrien
if you think about it, a little trickle of water isnt going to do much to a lump of metal running at 400 degrees (on light boost lol) the series one dont have it, and neither do alot of t34's?
have u had any probs with it disconnected, ie cracked turbo housings?
Old Feb 17, 2006 | 11:27 AM
Oranoco's Avatar
Oranoco
My Escort has retained it's water cooling and it's not too bad temps wise. I even went through the hassel of retaining the water cooling when my Fiesta was converted to T3.
My brother runs his T3 converted Fiesta with no water cooling and all is fine on his
JK12
33
Apr 26, 2021 12:09 PM
Matt Baxter
Sep 16, 2015 08:30 PM
Bailes1992
Sep 3, 2015 02:17 PM
robbo9006
11
Sep 1, 2015 02:10 PM
muz
Aug 16, 2015 12:57 PM
