oil
Old Feb 13, 2006 | 09:47 PM
signdesign's Avatar
signdesign
Default oil
what is the best oil to use on a cossie
Old Feb 13, 2006 | 11:23 PM
twitchyrear's Avatar
twitchyrear
mobile1 motorsport 15w 50
Old Feb 14, 2006 | 07:38 AM
signdesign's Avatar
signdesign
i used castrol rs but found it made my engine noisy.
i see u are using greys what fuel pressure do u have i was told 3psi but not sure i found when i was on boost in first gear then change to second and it was like it was running out of fuel so u had to wait a minuite for it to run back smoothly so i have bougt anew fuel pressure reg with gauge on it so i could see the pressure .it has a brand new 044 pump.......any ideas ?????
Old Feb 22, 2006 | 09:02 AM
330bhpcoz's Avatar
330bhpcoz
rs castrol 10//60
Old Mar 1, 2006 | 10:12 AM
oilman's Avatar
oilman
Wrong, wrong wrong!
5w-40 unless oil temps are excessive (above 120degC) then 10w-50
Simon
http://www.opieoils.co.uk
Old Mar 10, 2006 | 09:50 AM
330bhpcoz's Avatar
330bhpcoz
y is that
Old Mar 10, 2006 | 12:01 PM
Ridgey's Avatar
Ridgey
Most of the cossie specialists around the country many of who have raced these machine suggest to me mobil/castrol 15/50 or 20/60.
Much thicker than 5/40, due to the extreme temps in the turbo that would thin out lower rated oils too much??
Old Mar 10, 2006 | 03:47 PM
oilman's Avatar
oilman
Originally Posted by 330bhpcoz
y is that
Its just too thick when hot, nearly as thick as gear oil, this results in excess heat (friction) lower bhp (oil drag0 and ultimately more wear.
Simon.
Old Mar 10, 2006 | 03:49 PM
oilman's Avatar
oilman
Yes and no.
If you have very high temps you will need a 10w-50/15w-50.
The Castrol RS is mineral based and will shear down under hard use, a top quality ester/pao synthetic 5w-40/10w-50 will take more heat and punishment then a mineral based 10w-60.
Guy.
Old Mar 10, 2006 | 05:42 PM
escortrsmatt's Avatar
escortrsmatt
is esso ultron 5/40 suitable for use in a cossie?or mobil 1 10/40?
Old Mar 10, 2006 | 07:16 PM
oilman's Avatar
oilman
Yep the esso is fine, the Mobil is a semi synthetic.
Guy.
Old Mar 11, 2006 | 04:07 PM
330bhpcoz's Avatar
330bhpcoz
well i use castrol 10/60 runs ffine
Old Mar 11, 2006 | 08:32 PM
DAN-Saff's Avatar
DAN-Saff
TORCO 20/50
Brickhouse
14
Oct 3, 2015 07:28 PM
DAZZER
Sep 30, 2015 08:43 PM
Fudgey
21
Sep 30, 2015 06:19 PM
deathrider666
Sep 28, 2015 06:12 PM
