Popping
Old Feb 13, 2006 | 06:17 PM
rizla's Avatar
rizla
Default Popping
Does any body else get this And no it aint got anti lag
Dont do it often but every now and then i here it when i change gear and back off the gas it does it some times
Any advise on this plz
Old Feb 13, 2006 | 06:53 PM
Simon Day's Avatar
Simon Day
Does not sound like a big issue just a bit of unburned fuel - get the fueling checked.
Old Feb 13, 2006 | 07:19 PM
dave cos4x4's Avatar
dave cos4x4
probably only happens when you have been booting it.
the exhaust must be red hot to light the unburnt fuel inside the ex.
happens to most cars.
i had big 'boooom!' out of my old car sometimes.
Old Feb 13, 2006 | 08:31 PM
rizla's Avatar
rizla
Thanks for that Simon and Dave im just waiting till i can get a day off to get it to Engine Advantages to have it Power Run and check every things set up ok
Does drive so well no misfires etc whats the odd POP sounds well
Old Feb 13, 2006 | 08:33 PM
rizla's Avatar
rizla
And there is a lot of black dusty stuff in the tail pipe i notice it on the rag when i polish it
Old Feb 13, 2006 | 08:34 PM
Simon Day's Avatar
Simon Day
As long as you have got no det. you should be fine, make sure you post your power figures!
Old Feb 13, 2006 | 08:46 PM
rizla's Avatar
rizla
What do you mean by det mate
Old Feb 13, 2006 | 08:55 PM
Simon Day's Avatar
Simon Day
Detonation. - not good! If the fueling and boost are not correctly set and the plugs are not doing their job then the car will start pinking (detonating) and this can lead to piston meltdown!
Old Feb 13, 2006 | 09:02 PM
rizla's Avatar
rizla
It deffo aint pinking mate and i only ever put optimax in but i will get him to check things before it goes on rollers
Old Feb 13, 2006 | 09:57 PM
dave cos4x4
the black dusty stuff is because slightly overfueling.
its soot from the fuel getting burnt.
most cossies are like this, better to overfuel a bit than under fuel.
Old Feb 14, 2006 | 04:05 PM
rizla's Avatar
rizla
Sounds right to me mate Cheers
Old Feb 14, 2006 | 09:02 PM
dave cos4x4
no problem at all.
Old Feb 18, 2006 | 06:29 AM
bunjeeman's Avatar
bunjeeman
Sounds like you may have a leak in your exhaust there m8! As the other guys gave said, most of the cossies are overfueled anyway and when there is a leak in your exhaust, air can get into the system and you will ignite the unburnt fuel in the exhaust, hense the popping.
I had the same problem on 2 of my cars, the leaks on my mine were where the downpipe connects to rest of the system.
Hope this helps!
Old Feb 18, 2006 | 10:11 PM
rizla's Avatar
rizla
Hope this helps!
Thanks mate ill check it out you never no
IainRS1700T
Sep 25, 2015 06:44 AM
Iain Mac
Sep 13, 2015 09:16 PM
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
rsturbo27
Sep 5, 2015 05:08 PM
