funny noise from the engine bay
Old Feb 13, 2006 | 08:40 AM
anodised's Avatar
anodised
Default funny noise from the engine bay
i all need some help my dads got a v6 cougar and when he starts it up from cold and moves the steering it makes a loud whining noise which then goes by the time he leaves the street (100M) then occasionally it does it again when driving but its intermitten.
its only started after it was serviced and found to have a leak on the power steering pipe. the pipe was fixed and power steering fluid was topped up
the car also has a induction kit fitted and a de-cat
thanks
lewis
Old Feb 13, 2006 | 08:49 AM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
suonds like bairings in power steering pump are going
poss try bleading sysem by taking cap of power steering fluid and holding the steering on full lock both ways for aprox 15-20secs each time
DONT FORGET TO PUT CAP BK ON
also check tesion on belt
tommy
Old Feb 13, 2006 | 03:16 PM
Bouncing Cougar's Avatar
Bouncing Cougar
Default Re: funny noise from the engine bay
Hi Anodised
could it be moosing ? I had this problem on cold starts & the noise started when I moved the steering wheel, but the noise lasted for about 5 miles or until the engine warmed up !
I cured mine with the anti moosing pipe from ford......'HOSE-AIR' part number 1025296
Mine cost Ł31.75p & it's easy to fit
Hope it is moosing & it's nothing too serious
Old Feb 13, 2006 | 04:04 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
GOOD POINT THERE M8
Old Feb 13, 2006 | 06:03 PM
anodised's Avatar
anodised
i am going to try the moosing fix kit i ve been told about this will see what it does will let u know thanks for the help
bigryrs
Mar 28, 2016 09:11 PM
bigryrs
Fiesta RS1800/RS Turbo
14
Jan 21, 2016 09:54 PM
YODI
Aug 30, 2015 01:12 PM
RSmark84
20
Aug 24, 2015 02:17 AM
track.focus'd
Aug 12, 2015 05:53 PM
