Oil Level
Old Feb 12, 2006 | 07:30 PM
S1rst's Avatar
S1rst
Default Oil Level
At what level on the dipstick do people run their cars at. Ive always had it on the full mark or just under.
A few have told me to keep it between half way between the lines and 3/4?????
Thanks, Rich.
Old Feb 12, 2006 | 08:35 PM
jurk's Avatar
jurk
I leave it on the bottom of the recomended value - MIN - otherwise i get oil in the airbox
Old Feb 13, 2006 | 01:55 PM
Tandy's Avatar
Tandy
always keep mine at max
Old Feb 14, 2006 | 03:58 PM
Damo V's Avatar
Damo V
Check oil level once oil has been left to settle after running, best bet is to check it after you have filled up with fuel and been in to pay..
Oil level should be kept halfway between minimum and maximum
Old Feb 14, 2006 | 04:17 PM
rizla's Avatar
rizla
Mines on the max ill let it go down abit
Dont get none in air box or pipe from the air box to turbo i just checked
Old Feb 14, 2006 | 04:20 PM
SHITBOX's Avatar
SHITBOX
Between 3/4 and max.
Old Feb 14, 2006 | 06:04 PM
S1rst's Avatar
S1rst
Seems to be a few different views on this then. Ive heard a few saying when on MAX, they get oil in the airbox pipe.
Not sure what to do now really???
Old Feb 14, 2006 | 06:17 PM
rapidcossie's Avatar
rapidcossie
will prob get oil in airbox when on max beacuse of poor breathing.
i always run mine on max and never get any oil in breather sytem
Old Feb 14, 2006 | 06:40 PM
rizla's Avatar
rizla
I did have a bit of oil in the air box
But sence 330 cossie fitted the new bailey breather kit nothing at all now and ive took it for good runs to try it out
The original breather that was fitted to car was all sh*tted up
I knew it needed one when i went to buy its best thing fitted so far
Old Feb 14, 2006 | 07:00 PM
rsdene's Avatar
rsdene
i leave mine right @ the top never had a problem i would never run it @ min
Old Feb 14, 2006 | 07:11 PM
cozzymatt's Avatar
cozzymatt
I always try to keep mine on the max level....
Old Feb 14, 2006 | 07:34 PM
Speedy G.'s Avatar
Speedy G.
And what if you leave home after the car has been standing for some time then?
Old Feb 15, 2006 | 04:21 PM
Damo V's Avatar
Damo V
Unless the oil pixies come along and remove your sump plug you wont have a problem...
If you check the oil level at home before moving off and its too low, that would also suggest it was too low when you parked the car up ROFL
Old Feb 15, 2006 | 04:25 PM
Damo V's Avatar
Damo V
Right THIS is all you need to know...
From the Escort Cosworth Owners Handbook....
Check the engine oil level each ime you refuel. After switching off the enginewait for a few minutes to allow the oil to flow back to the sump..... Blah Blah...The oil level is correct if the film on the dipstick is between the two markings... blah blah.....The quantity of oil represented by the space between MIN and MAX markings is approx 0.5 to 1.0 litre
The end
Old Feb 15, 2006 | 06:23 PM
Simon Day's Avatar
Simon Day
The end
Old Feb 15, 2006 | 07:03 PM
rizla's Avatar
rizla
Originally Posted by Simon Day
The end
Brickhouse
14
Oct 3, 2015 07:28 PM
DAZZER
Sep 30, 2015 08:43 PM
Fudgey
21
Sep 30, 2015 06:19 PM
deathrider666
Sep 28, 2015 06:12 PM
