de-ABS-ing a Fiesta turbo
Old Feb 12, 2006 | 03:51 PM
feestk150's Avatar
feestk150
Default de-ABS-ing a Fiesta turbo
i was wandering how much work is involved to remove the abs from my fiesta?
its got poor braking power and hav been told im best getting rid!
Old Feb 12, 2006 | 04:17 PM
fezzanut's Avatar
fezzanut
i think all u need 2 do is remove abs belts from driveshafts remove abs unit and take out the bulb from behind the clocks so the light dont stay on.im not 100% sure though i think u may need 2 replace the master cylinder.mines been de-absed but it was done before i bought the car
Old Feb 12, 2006 | 04:32 PM
feestk150's Avatar
feestk150
ok cheers
sombody told me that i would have 2 repipe the brakelines?
any ideas?
Old Feb 12, 2006 | 04:36 PM
Oranoco's Avatar
Oranoco
Fuck no!
You need to have the modulators removed and replacement pipework plumbing in. It is a very good mod to do as improves the brake feel hugely. The standard FRST brakes are lame at the best though so before binning the ABS I would look at converting to Cossie discs and calipers. If they still don't feel good enough then bin the ABS.
Fiesta turbo brakes are pretty much identical to XR2i brakes and to be honest I don't rate them for stopping the 108bhp car never mind one with at least 130
Old Feb 12, 2006 | 04:42 PM
feestk150's Avatar
feestk150
yeah well its putting out just over 200bhp so u will understand my concern!
ive got a set of front brakes off an mk5 xr3i 130 sitting in my garage, would they b a decent upgrade if they fitted?
Old Feb 12, 2006 | 04:53 PM
Oranoco's Avatar
Oranoco
May be an improvement of sorts but I wouldn't have thought it will be an adequete improvement.
I can relate to your predicament as my own Fiesta is knocking out 207bhp and is also still on standard brakes. It's not used at all much and they are to be done this year before the show start to get into full swing
Old Feb 12, 2006 | 05:02 PM
feestk150's Avatar
feestk150
im right in saying its the 4x4 cossie callipers and discs i need and not the 2wd 4-pots?
Old Feb 12, 2006 | 05:09 PM
Oranoco's Avatar
Oranoco
You would be right mate. I beleive the 2wd calipers can be made to fit but need a bit more work.
Old Feb 12, 2006 | 05:13 PM
sy16v's Avatar
sy16v
Had my ABS removed and put cossie brakes on much better. i got a garage to get rid of my abs as seemed alot of work was needed and yes its 4x4 cossie brake you need
Old Feb 12, 2006 | 07:30 PM
feestk150's Avatar
feestk150
cheers guys
i'll get on the case.
Old Feb 13, 2006 | 11:30 AM
bud-weis's Avatar
bud-weis
Football Cwazy
i did this on my old fez, with the following brakes
front
rear(before they were repainted)
basically i removed the whole ABS system and all pipes,i also removed the shockingly bad rear load compensators and ran pipe straight to the calipers on the rear, i then got some copper brake line and with the car on axle stands all round offered up and shaped the lines, once i was happy with the length/shape i took them to my local motor factors and they flared the ends for me.
I changed the master cylinder and fitted mondeo brake pressure reducing valves to it,you can just see them here;
( these do the job that the compensators weren't doing,without these the back end will just lock up under braking)
it is much better without ABS
Matt Baxter
Sep 16, 2015 08:30 PM
Ben26
Aug 27, 2015 08:56 PM
paceo
Aug 27, 2015 12:45 PM
turbobill
Aug 1, 2015 08:55 PM
