chatter
Old Feb 12, 2006 | 09:01 AM
sara's Avatar
sara
sara
Default chatter
how do u make a frst chatter is it just a decent induction kit
Old Feb 12, 2006 | 09:08 AM
croppy's Avatar
croppy
put a cone on it an no dump valve
obviously the more boost the louder it would be
Old Feb 12, 2006 | 09:11 AM
sara's Avatar
sara
sara
it has a k&n cone now and dump valve just remove the gay valve ant its chatter away
Old Feb 12, 2006 | 09:19 AM
danfrst's Avatar
danfrst
Youre right just add an induction kit, my frst was standard when i put a piperx kit on-hadnt expected the 'chatter' but it was a nice surprise!!
Old Feb 12, 2006 | 09:26 AM
sara's Avatar
sara
sara
sweet cheers peeps
Old Feb 12, 2006 | 09:45 AM
petermintrst's Avatar
petermintrst
does the same happen with an erst?
Old Feb 12, 2006 | 09:49 AM
Šhatter Box's Avatar
Šhatter Box
only on some
Old Feb 12, 2006 | 09:54 AM
Robert_Cox's Avatar
Robert_Cox
i thought chatter was an undesirable effect? back pressure hitting the blades of the turbo causing it to stop or slow down very suddenly?? the idea of fitting a dump valve was to eliminate that chatter and prolong the life of the turbo?
Old Feb 12, 2006 | 10:01 AM
petermintrst
only on some
um which some?. or is just luck/unluck of the draw
Old Feb 12, 2006 | 10:22 AM
Oranoco's Avatar
Oranoco
The effects on an RST are minimal. It'ds only going to prolong the life of your turbo if you buy into the marketing bullshit. If you are running 30psi or more boost then these effects could be damaging but under this level you don't need one.
Old Feb 12, 2006 | 10:37 AM
matt p's Avatar
matt p
Default Re: chatter
Hey take it you got it then?
Old Feb 12, 2006 | 11:37 AM
adamS2RST's Avatar
adamS2RST
only on some
lol @ Alex.
Peter, your standard MFI car won't chatter.
Old Feb 12, 2006 | 11:50 AM
Sexy-RS's Avatar
Sexy-RS
only on some
lol @ Alex.
The red s2 mfi we had last year chattered
Old Feb 12, 2006 | 11:57 AM
adamS2RST's Avatar
adamS2RST
only on some
lol @ Alex.
I knew it wouldn't be long before someone said something! Yes, ok ok if you run a decent amount of boost, it may do it, but it won't be like a frst as the metering head muffles the sound out. My standard MFI S2 does it a little bit...think it's got an air leak somewhere though!
Old Feb 12, 2006 | 12:03 PM
Oranoco's Avatar
Oranoco
My S2 does a bit but nothing like the Fiesta. Only reason I have chatter is I can't stand DV's
petermintrst
only on some
lol @ Alex.
good, the answer i wanted
Chas
Sep 21, 2015 08:57 PM
nice_head
76
Aug 22, 2005 09:17 AM
thelynx
Feb 26, 2005 10:33 PM
DaveRS
Feb 3, 2005 04:59 PM
MadMac
56
Jan 7, 2005 09:09 PM
