will it fit?
Old Feb 10, 2006 | 03:25 PM
orion_crazy_carl's Avatar
orion_crazy_carl
orion=mini saff
Default will it fit?
hi peeps,im just after a quick bit of advise!ive got a 3 door cossie,was just wundering whether saff cossie suspension is the same,as im a cossie virgin
thks
Old Feb 10, 2006 | 06:19 PM
grunter's Avatar
grunter
i believe the 2wd sapph and 3 door use the same gear mate but just not a 100% sure
Old Feb 11, 2006 | 09:38 AM
K.Goa's Avatar
K.Goa
there is some small differences in the rear semi-trailing arms. the mounting points off the stabilizorbar is different. at front the balljoints of the TCA`s i different.
Old Feb 11, 2006 | 09:39 AM
K.Goa's Avatar
K.Goa
anti-rollbar is probaly the correct word
Old Feb 11, 2006 | 05:19 PM
cossie604's Avatar
cossie604
^^^^ that aside, if you mean just a set of dampers and springs then yes, they are interchangable
Stu.
Old Feb 11, 2006 | 05:39 PM
orion_crazy_carl
orion=mini saff
ahah,cheers ladz,very helpful
Kyle Langford
27
Aug 5, 2019 07:54 PM
ekjim
Aug 27, 2015 05:20 PM
Dr. Ickxs
Aug 15, 2015 11:34 AM
marky_g
Aug 15, 2015 10:43 AM
track.focus'd
Aug 12, 2015 05:53 PM
