swirll pots
Old Feb 10, 2006 | 11:15 AM
jimmylaud's Avatar
jimmylaud
Default swirll pots
hi guys just wondering how you fit a swirll pot and help would be perfect cheers
Old Feb 10, 2006 | 11:22 AM
Tony Turbo's Avatar
Tony Turbo
www.ctuceilings.co.uk
ERST?
You already have one
Old Feb 10, 2006 | 11:25 AM
jimmylaud's Avatar
jimmylaud
i just bought a chrome and it has three out lets on it wasnnt very sure where to join it in
Old Feb 10, 2006 | 11:27 AM
jimmylaud's Avatar
jimmylaud
forgot to say there it is the erst cheers guys
Old Feb 10, 2006 | 11:37 AM
Tony Turbo's Avatar
Tony Turbo
... Wasn't a question
If you wish to fit another then it goes in the top rad hose next to the one you already have. Take the hose from the header tank that goes to the thermostat housing/ swirl pot and put it on to your new swirl pot and block the original one off.
Old Feb 10, 2006 | 11:46 AM
jimmylaud's Avatar
jimmylaud
cheers for your help it was just that i got a new header tank from a+s and it has three out lets on it they say thats for running the swirll pot maybe just blank the third hole and send it back
Old Feb 10, 2006 | 09:34 PM
zippyobrien's Avatar
zippyobrien
if youve got a shiney new header tank with 2 small out lets at the top, this is for running the standard swirl pot (part of the themostat housing and an external one at the same time
Old Feb 10, 2006 | 09:39 PM
Ad4m RST's Avatar
Ad4m RST
Jiu Boxu
if its got 3 outlets isn't that an oil separater?
if so the top two outlets go to the pipes leading out of the rocker cover, and the 3rd to the pipe from the back of the block.
Old Feb 10, 2006 | 09:45 PM
zippyobrien
Originally Posted by jimmylaud
cheers for your help it was just that i got a new HEADER tank from a+s and it has three out lets on it they say thats for running the swirll pot maybe just blank the third hole and send it back
header tank dude
Old Feb 10, 2006 | 09:53 PM
CHRISP's Avatar
CHRISP
has two outlets at the top....
...will probably have an outlet on the top...not shown..
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
OrionRST200bhp
Sep 29, 2015 08:30 PM
IainRS1700T
Sep 25, 2015 06:44 AM
Minirotty
11
Sep 15, 2015 10:16 PM
