ERST probs
My scort has been sitting for 2 months whitout it being driven, and now my brakes are completely gay, the pedal almost go to the floor now and my clutch is "jumping", what can that be? The clutch was slipping before and dosent do that now, now it "jumps" and the brakes was working fine before and now they barely can brake. Anyone know what the problem is?
Brakes, check out your brake cylinders, may be leaking. Check the fluid level in the resi. Might just need bleeding again
Clutch...no idea! But if it was slipping previously maybe it's said enough is enough ?
Mc5506
Oct 5, 2015 09:57 PM
