What clutch for ERST. One which wont need changing.....
Old Jul 22, 2004 | 07:51 PM
L33 BYT's Avatar
L33 BYT
Default What clutch for ERST. One which wont need changing.....
......When I have upped the power a little more. Dont really want a 6 paddle cos I hate harsh bite.
What are these organic plates like.
Car is only about 10/20 BHPmore than standard currently.
Old Jul 22, 2004 | 08:09 PM
DazC's Avatar
DazC
My 6 paddle Alcon doesn't bite harsh at all mate.....
My mates 4 paddle is on or off.....
Old Jul 22, 2004 | 08:11 PM
Exeter J's Avatar
Exeter J
Think you mean 4 paddle chap - which is most commonly used
A 6 paddle would be much better for bite than 4, as it allows some slip but also takes the power - don't think many peeps do them except here....
http://www.ears.co.uk/acatalog/Onlin...tches_155.html
Old Jul 22, 2004 | 08:12 PM
L33 BYT's Avatar
L33 BYT
Whoops Yeah I was just testing you lot knew what ya talking about
Old Jul 22, 2004 | 08:17 PM
GrahamM's Avatar
GrahamM
I had an AP Racing Organic clutch on my old S2 and had no problems in over 5 years and 25,000 miles. My S2 had just over 160bhp.
Old Jul 22, 2004 | 08:18 PM
Exeter J's Avatar
Exeter J
Agreed on the bite thing though - think the 4 paddle was the worst thing i ever put on my old RST - ruined it as a half town/cruise car and half B road bomber. Would have been ok if it was just a track car though. Heard the 6 paddle is sooo much better though.
Rick's Avatar
Rick
The std one will be fine - or if u want a lot more power then an AP organic, but they can get quite heavy depending on what plate u go for. Stay away from a paddle, they not meant for high mileage motors.
Old Jul 22, 2004 | 08:28 PM
L33 BYT's Avatar
L33 BYT
The std one is new and fooking slipping so need to change it.
Old Jul 22, 2004 | 08:29 PM
Rick's Avatar
Rick
well it's unlikely to be the fault of the clutch. The flywheel may need skimming, and ur rear crankshaft oil seal may be leaking. Mine didnt slip at 210bhp.
Old Jul 22, 2004 | 08:32 PM
L33 BYT's Avatar
L33 BYT
This post is a follow up from here mate...
https://passionford.com/forum/viewtopic.php?t=63508
Old Jul 22, 2004 | 08:47 PM
DazC's Avatar
DazC
Get the flywheel surface ground, check that the rear main oil seal is not leaking (if so, replace) then fit a new full clutch kit.
I opted for the 6 paddle Alcon clutch which gives near standard pedal feel and a progressive bite. I was offered another option which was about £600 which was a twin plate clutch! I decided to see how well the paddle performs!!!
Old Jul 22, 2004 | 08:54 PM
Rick's Avatar
Rick
I saw ur paddle Daz, looked cool as Interesting to see how it lasts - if this AP decides to let go it'll be my next choice.
Old Jul 22, 2004 | 08:58 PM
Oranoco's Avatar
Oranoco
Standard clutch should be completely fine at this power level mate. I'd be looking at the flywheel's surface and possible oil cotamination of the clutch unit.
Old Jul 22, 2004 | 09:01 PM
L33 BYT's Avatar
L33 BYT
Deffo not oil. face was checked with straight edge and feeler guages.
Fooking motor.
Old Jul 22, 2004 | 09:16 PM
Rick's Avatar
Rick
well then clutch is faulty - get new one under warranty - its as simple as that.
Old Jul 22, 2004 | 11:43 PM
kevsrs's Avatar
kevsrs
Mate, i got the standard clutch runnin about 150bhp and it is spot on
I don't know if this helps, i don't know too much about it but don't think it's your clutch IMO
Old Jul 23, 2004 | 05:39 AM
John Laverick's Avatar
John Laverick
I ran about 180BHP on the standard clutch, very very good unit as standard
Old Jul 23, 2004 | 08:35 AM
Tony Turbo's Avatar
Tony Turbo
www.ctuceilings.co.uk
Same here, 220bhp and on standard clutch was fine. I highly rate the standard FORD clutch up to this level of power.
Old Jul 23, 2004 | 09:39 AM
matts1's Avatar
matts1
I,ve just fitted an 220mm organic AP CP2000-8 clutch to the S1, seems to be handling the power at the moment and drives fine. Did need to change the pedal and quadrant (the AP site gives full details and part numbers), but that was easy enough and isn't always needed, fit it first and see how it feels, if the bit is to low down or you can't get t the gears then change the pedal etc
I wouldn't go for a cheaper version of the organic clutch as they apparently aren't much better than standard. stick with AP, you'll feel the quality
Old Jul 23, 2004 | 10:04 AM
Rsmat's Avatar
Rsmat
i run about 195bhp in mine and mine as standard clutch m8 if that help
Old Jul 23, 2004 | 10:31 AM
Oranoco's Avatar
Oranoco
Mines using a Helix organic clutch and seems (so far) to be coping with the 248bhp I've been hammering through it
Old Jul 23, 2004 | 12:39 PM
Lemon S2's Avatar
Lemon S2
I've got the AP 4 Paddle clutch and as said above it's either on or off no in between. Before this I was was a fast road clutch which was only about £120 or around there & that was fine for 200bhp and it didn't wear down to quickly either.
HTH
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
Mc5506
Oct 5, 2015 09:57 PM
