series one fan not kicking in? and heaters arnt very hot
Old Feb 9, 2006 | 11:05 PM
stusfesta's Avatar
stusfesta
Default series one fan not kicking in? and heaters arnt very hot
as above... thought it was just the fan switch but the heaters are barely warm either now
Old Feb 9, 2006 | 11:33 PM
MikeyXR2i's Avatar
MikeyXR2i
possible the thermostat is stuck open, or theres not one in there at all making it much longer to warm up, fan won't come on if nothings getting hot.
Old Feb 10, 2006 | 11:43 AM
stusfesta's Avatar
stusfesta
the temperature will go rite up wen car is stationary but fan still wont cut in and heaters still arnt hot, just slightly warm
Old Feb 10, 2006 | 04:32 PM
B16 WLD's Avatar
B16 WLD
you dont say if it is running at normal temperature or lower.
first off bridge the fan switch by linking out the two cables connected to the switch, if the fans work this needs replacing.
the heater problem may be due to a clogged up matrix!!
Old Feb 10, 2006 | 04:35 PM
Mr S1's Avatar
Mr S1
Don't ask - I don't know
I'd flush the system first and change the thermostat if you run one. I don't personally, but I only use my S1 in the summer anyway. May find the heater matrix is blocked. You can stick a hose down it and that may clear it, but they have a habit of bursting if you do that and then end up with a puddle inside the car..............so be warned !!!
Old Feb 10, 2006 | 04:38 PM
stusfesta's Avatar
stusfesta
runs at normal temp untill wen the fan would normally kick in, yea fan kicks in wen bridge the wires, ford dont sell the switch anymore with the rite connection anyway. where abouts will the matrix be clogged?
Old Feb 10, 2006 | 04:42 PM
B16 WLD's Avatar
B16 WLD
the matrix is in the heater box,to flush it out run water through it. to find it follow your water pipes to the bulk head, you will see to connectors, they are the in and out, carfull though the do burst!!
Old Feb 10, 2006 | 04:49 PM
stusfesta's Avatar
stusfesta
yea thought it was them, had one of them burst the other month. any ideas which one in and which one out? lol
Old Feb 10, 2006 | 04:53 PM
B16 WLD's Avatar
B16 WLD
not completely sure on fiesta, have a look in the manual if you have got one if not prob time to you can flush both ways, just take it easy
Old Feb 10, 2006 | 05:03 PM
stusfesta's Avatar
stusfesta
its a series 1 escort, sorry im stuck with the user name and dunno how to make a new sig lol
Old Feb 10, 2006 | 07:58 PM
MikeyXR2i's Avatar
MikeyXR2i
Ford parts UK have the correct fan switch for the S1
Old Feb 11, 2006 | 01:08 AM
SafeChav's Avatar
SafeChav
stusfesta: I'd get yourself a new thermostat first off, notoriously shit on all CVH engines (fairplay they did make a pigs ear of designing CVH didn't they )
My one came from halfords, cost about £4, and my car runs amazingly cool, heaters are roasting, drive along at 10 miles per hour and the temp needle sits right down, obviously in traffic it does get hot and the fan cuts in, but it is excellent IMO, warms up quickly too (again notoriously crap for warm up times)
If your fan isn't cutting in even when its left at stand still its going to be the thermostat. If you turn the heaters on when its stationary i bet the heaters go cold in a matter of seconds yeah? And no heat when driving?
Old Feb 11, 2006 | 10:08 AM
stusfesta's Avatar
stusfesta
safechav. cheers for that i will go and get a new thermostat today or tomorrow, yea the heaters go cold in matter of seconds but are warm when driving but not hot! do u not think my fan switch is gone then?
Old Feb 11, 2006 | 11:34 AM
SafeChav's Avatar
SafeChav
If the fan switch was gone when left it would get hot, the needle would go up into the read and it would boil over and piss all the coolant out the overflow pipe.
Whats the temperature needle reading?
Old Feb 11, 2006 | 05:52 PM
stusfesta's Avatar
stusfesta
Yeah the temperature gauge goes rite up if im not moving, i put the heaters on full to help it cool down but they arnt very hot. maybe ile get a new switch and thermostat
Old Feb 11, 2006 | 06:08 PM
SafeChav's Avatar
SafeChav
well theres on simple way to test the switch then, let the thing idle, and get hot, obviously you need to be ready to whip the fan switch off and bridge the terminals for if/when it boils. The fan should always cut in just before the car boils over, if the car starts to let coolant out the overflow get the fan running, and it would be safe to say the fan switch is fucked.
Old Feb 11, 2006 | 06:50 PM
stusfesta's Avatar
stusfesta
Well it definatly doesnt kick in and comes on if i bridge it so ile try and get hold of a new switch
Old Feb 11, 2006 | 07:00 PM
SafeChav's Avatar
SafeChav
Ok sounds like a good move, sounds lik you also need a matrix if thats the case though? Check to see if both the pipes to and from are as hot as each other?
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
AJC
Oct 8, 2015 11:09 AM
Kiran1600E
11
Oct 2, 2015 11:35 AM
muz
Sep 30, 2015 08:29 AM
Sep 28, 2015 10:05 AM
