ma erst's fuelling is up and down! help needed plz!!!
Old Feb 9, 2006 | 06:49 PM
rsmycase's Avatar
rsmycase
Default ma erst's fuelling is up and down! help needed plz!!!
i blew the head gasket on ma rs so i changed the gasket then took it 2 a local garage 2 get the timing done, but when that was done it wudnt run rite cos 1 minute it wud b runnin far 2 rich then it wud b runnin far 2 lean! so help needed plz!
Old Feb 12, 2006 | 10:01 AM
SafeChav's Avatar
SafeChav
When i dropped my engine in my cabby it started and ran fine, but back fired something chronic, i just assumed it was cos it wasnt set up, took it to a mate to set it up and it was chucking out something ridiculous like 1500+ hydrocarbons out the exhuast, then the next minute it was going right down. We found 1 cylinder to be overfuelling by the plugs, 1 being totally black, metering head was fucked. Have a look at your plugs they will tell you a lot...
JoeyBoyden
Jan 4, 2024 02:36 PM
borboyous
Aug 22, 2015 11:17 AM
Ellsa
Aug 9, 2015 07:03 PM
col93saphcos
Aug 7, 2015 03:21 PM
