Turbo's on AVA manifold
Feb 9, 2006 | 04:36 PM
pretty specific but does anyone have close up pics of their turbo's mounted to ava manifold...
T28, gus, B8 maybe
cheers
Feb 9, 2006 | 04:57 PM
only one i have im afraid
what ya need to know then?
Feb 9, 2006 | 05:03 PM
jus looking into housings and downpipes really...
what setup did you have again?
cheers
Feb 9, 2006 | 05:04 PM
I will take some tomorow
Feb 9, 2006 | 07:09 PM
Much aprreciated cheers.
Feb 9, 2006 | 08:18 PM
think i had a 63 rear housing on mine cant remember now
got meself a shiny new turbo and dont know what housing is on that either
Feb 9, 2006 | 08:32 PM
Ok because i've just got a T34 with .48 housing but its fouling on the manifold so must be wrong type. I have the right parts from when i had a stage 3 T3 but not sure if they would be up to the job....
I knew you had the T34 so just made me think
Feb 9, 2006 | 10:29 PM
gus
yours had a 38 or a 36 exhaust housing cos i just had it changed for a 48!
hope this helps!
Ad4m RST
also it used the standard turbo exhaust elbow!
I dont M8 sorry I lost the majority of the pics that I did have
Good lad Dave
Feb 9, 2006 | 10:39 PM
Cheers dave helps alot.
B8 what housing did you have? whats the biggest that you can use with this manifold?
Feb 9, 2006 | 10:41 PM
Mine must be fairly small with me having the T28
Feb 9, 2006 | 11:51 PM
B8
Ad4m RST
Feb 10, 2006 | 04:38 AM
i really should pay more attention
Feb 10, 2006 | 06:34 AM
Feb 10, 2006 | 03:35 PM
will see it when i get down to see me engine soon
might have to get me engine bay mirrored so can see it properly
Feb 10, 2006 | 05:07 PM
63 housing isnt a problem, or shouldnt, as the manifold retains the original turbo position.
Im sure Davie(not T28) had a .63 on his
T34 or T38 going on new build with same manifold.
Feb 10, 2006 | 06:24 PM
I've just got a T34 with .48 housing and it doenst fit the manifold at the moment...absoloutely no room for a downpipe aswell...
i'l get a pic up to show you what i mean soon as...
Feb 10, 2006 | 06:42 PM
Feb 10, 2006 | 07:19 PM
Very difficult to see from the quality of the pics, if you get some better 1's sorted i'll do everything I can to assist.
From what I can see it would appear that 1 of the bolts needs shortned this would then allow the down pipe to marry up a lot easier.
Both davidch's and my own have custom 3" down pipes which will come into the equasion.
Davie (T28) is your down pipe standard? I know you will have the flexi section further down, but was it modified at the turbo end?
Feb 10, 2006 | 07:29 PM
yeah once screw defo too long, but also seems like where the housing would meet the downpipe is too wide. Most probably need a custom job like you...
i'll get brighter pics up when i can, cheers for help so far
Feb 10, 2006 | 07:38 PM
I dont have an elbow coming off the turbo, its a one piece pipe
If this helps in any way
Feb 11, 2006 | 08:34 PM
yeah defo helps. So you need a custom downpipe for the manifold, i'll get on it.
Did ava fabricate yours T28, B8??
Feb 11, 2006 | 10:19 PM
Yup, all of the other manifolds of the type you now have were fitted by AVA to the customers cars. Gus's being the only exception.
Remember and have a flexi section fitted, assuming you dont already have one. Not using a flexi section will put more strain on the manifold and may well lead to your manifold cracking.
Not that any have cracked, but prevention is better than cure. Or so they
say.
This may or may not help.
Feb 11, 2006 | 11:59 PM
again helps alot...
I was aiming to go down the ALS route, gus ran it with T34 on this manifold so can be done. Just wondering how the maram shaft would fit if i'm having these problems...
i'll defo speak to ava though, thanks again B8
Feb 14, 2006 | 05:35 PM
how many different companies are doing the tubular manifold now? i think performance ford are supposed 2 feature a company next month? who recommends what then?
Feb 14, 2006 | 06:15 PM
Quote:
AVA dont just do manifolds for anybody,they only do them for cars that they built engines for to get the most or best driveability out the car
Feb 14, 2006 | 07:01 PM
guess i got lucky then
JK12
33
Apr 26, 2021 12:09 PM
xrmalin
Sep 13, 2015 06:52 PM
kevin36
Sep 2, 2015 06:24 PM
mrknifey
Aug 30, 2015 11:48 AM
