WHAT IS THE CORRECT PLUG FOR 4X4 STG 3 COSSIE
Old Feb 9, 2006 | 05:48 AM
NAKRS's Avatar
NAKRS
Default WHAT IS THE CORRECT PLUG FOR 4X4 STG 3 COSSIE
IM TRYING TO FIT THE CORRECT PLUG TO HANDLE 1.5 BAR BOOST ON MY COSSIE MODS ARE CHIP -31 3 BAR MAP SENSOR 803 DARK GREENS
PIPERCROSS INDUCTION PERFORMANCE ZORST GRP A HEADGASKET GRBA DUMPVALVE BREATHERKIT SILICONES
ANY INFO WOULD BE MUCH APPRECIATED
IS THERE MORE THAN 1 TYPE OF PLUG AVAILABLE FOR THIS SPEC.
Old Feb 9, 2006 | 07:08 AM
Alvyn's Avatar
Alvyn
I use Champion c59c on the same spec as yours WITHOUT any probs! others use standard Escort rs turbo plugs again without probs! and there are other types also!
Old Feb 9, 2006 | 04:25 PM
costina's Avatar
costina
Live long and prosper!!
pp8 escort cos plugs set at .6mm
every conversion i have done has had no probs.
i had a stint with greys and 30psi still no misfires
Old Feb 9, 2006 | 08:23 PM
rizla's Avatar
rizla
PP8s in mine
Old Feb 15, 2006 | 08:40 AM
NAKRS's Avatar
NAKRS
Default THANKS 4 THE INFO CHAPS
MY COSSSIE IS RUNNING SWEET AGAIN....
DixieTheKid
Jul 23, 2023 10:16 AM
Hellraiser
Aug 30, 2015 10:29 AM
wheelwizardrefurbs
Aug 29, 2015 09:25 AM
Caddyshack
Aug 19, 2015 07:29 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
