*****Anyone know of a good garage******
Old Feb 7, 2006 | 11:17 PM
Danny-p's Avatar
Danny-p
Default *****Anyone know of a good garage******
Message removed
Old Feb 7, 2006 | 11:26 PM
Doug's Avatar
Doug
If your head gasket has gone I can't see how that is MSD's fault ?
Old Feb 7, 2006 | 11:45 PM
Stu @ M Developments's Avatar
PassionFords Creator
Default Re: *****Anyone know of a good garage******
Originally Posted by Danny-p
Anyone know of a good garage round the north west that i can get my small turbo escoss running problems sorted once and for all and wont get ripped off or my car getting wrongly diagnosed. Need cosworth trined person or someone compitent. Tried (MSD new chip+ Bleed valve+30psi = blown head gasket )
car symptons
Stalling every now and then
blue smoke out of exhaust (just stopped)
Misfiring
low oil pressure
slow as f**k
Thanks if any one can help
If you are suggesting we chipped your T28 Escort, fitted a bleed valve and gave you 30psi your lying pal.
Old Feb 8, 2006 | 08:37 AM
maxest's Avatar
maxest
Mate, just cut your losses and sell it to a breaker!
Old Feb 8, 2006 | 08:39 AM
AlexD's Avatar
AlexD
Post Miester !
Erm........ Doubt that was MSD mate
I presume you mean you put a new chip in it, without setting it up ?
Al.....
Old Feb 8, 2006 | 08:46 AM
Danny-p's Avatar
Danny-p
wh
Old Feb 8, 2006 | 09:25 AM
Ahhhh, your Carolines (kennys ex missus) Nephew arent you?
Your car came here with serious running problems (suspected head gasket problems and you required it confirmed) the chip fitted to the car was a GGR chip that was faulty for some reason so to run it without hitting the boost limiter we advised fitting another chip which YOU agreed you wanted so we fitted one.
When the chip issue was resolved and we testd rove, we determined that the head gasket was indeed faulty and advised you of this, along with header tank cap failure and the amal valve was actually missing.
You had teh option of fitting a new one at £60 or a cheaper option was a bleed valve (Lockable 3 port) You chose the cheaper option so we fitted it and set the boost to a max of 18, as all Stg 1 escort T28s run. (where did you get your 30+psi reading from then?)
You were then given the bill and told your headgasket is failing as YOU originally suspected and we advise you dont use the engine hard until it is repaired for obvious reasons.
I recall you (or was it your dad?) were also upset that you wanted to pay only half the bill and have the other half on credit and Kenny refused you even though your semi related, so thats put your nose out of joint i guess? Sorry for you...
That sound's as little more like events as I remember them, but it was a while ago so forgive me any small inaccuracies......
Old Feb 8, 2006 | 09:38 AM
Danny-p's Avatar
Danny-p
ok
Old Feb 8, 2006 | 10:01 AM
I take it instead of taking it easy and getting your headgasket fixed when youd saved up, you took it out and thrashed it around and made it worse instead?
And your 30psi quote? Where was that measured?
Old Feb 8, 2006 | 10:08 AM
GUZZLER's Avatar
GUZZLER
Old Feb 8, 2006 | 10:29 AM
Another MSD bodge job
When will people learn not to use these cowboys
Fucking hell Stu, you can choose your friends but you cant choose your customers eh mate?
Absolutely priceless the massive difference between how he presented it and what actually happened, how the fuck can ANY business manage to keep a good reputation when jokers like this are running round bad mouthing them when they have done asbolutely nothing but the correct thing?
Old Feb 8, 2006 | 10:48 AM
Rob M666SCC's Avatar
Rob M666SCC
How events can differ from one mouth to the next
It would be much easier if people actually stated the whole facts in these cases
Old Feb 8, 2006 | 11:02 AM
MONSTER's Avatar
MONSTER
Danny-p Wouldn't it be appropriate to offer Stu an apology mate?
Old Feb 8, 2006 | 11:18 AM
Danny-p's Avatar
Danny-p
Default Appology
Apologised to stuart
Thanks MONSTER
Appolys to all been offended
F**ked up
Danny Has just Appologised via PM and admitted he offered the forum incorrect information. Im sure he will update this post too when he has time...
Thanks Danny.
Old Feb 8, 2006 | 11:20 AM
Default Re: Appology
Thanks MONSTER
F**ked up
No problem Danny, hope you get her sorted soon, these cars can be a real heartache pal but they are worth it once running properly.
Old Feb 8, 2006 | 11:23 AM
Danny-p's Avatar
Danny-p
Old Feb 8, 2006 | 11:26 AM
Nice one Danny-P
Old Feb 8, 2006 | 11:49 AM
frog's Avatar
frog
0-60 in 17 seconds (eek)
awwwwwww
Nice one Danny
Old Feb 8, 2006 | 04:44 PM
MONSTER's Avatar
MONSTER
Good man Danny
wheelwizardrefurbs
Sep 24, 2015 08:35 PM
3doorcozmess
Sep 15, 2015 06:06 PM
markk
Sep 9, 2015 08:11 AM
cbminis
Sep 7, 2015 09:42 AM
turbowag
Sep 3, 2015 08:07 AM
