loosing boost preasure
Old Feb 7, 2006 | 10:52 PM
vtr1981's Avatar
vtr1981
Default loosing boost preasure
1990 rst sluggish between 3000 and 3800rpm then preasure suddenly drops to 0 psi with a loud hissing noise then it hits 4000rpm hissing stops preasure jumps straight back up and car takes off like nothing will catch it.any ideas please.have checked hoses for leaks and cant find anything.cheers
Old Feb 7, 2006 | 11:07 PM
Andy-R's Avatar
Andy-R
If I were to say that it may be the small vacum pipes that are fitted either end of the plenum would that make sense to you?
They are usualy held on with jubilee clips or cable ties!
Its likely to be conected with air escaping from 1 of them.
That would be my initial impression.
Old Feb 7, 2006 | 11:32 PM
vtr1981's Avatar
vtr1981
is it likely to be the waste gate solenoid control valve
Old Feb 8, 2006 | 10:08 AM
Stu @ M Developments's Avatar
PassionFords Creator
Simple if it has a dump valve?
The dump valve fitted is leaking at peak boost. Bin it. Job done.
Old Feb 10, 2006 | 04:21 PM
vtr1981's Avatar
vtr1981
Default dump valve
removed the dump valve and the preasure gauge and still got the problem.just renewed all the vacume hoses on the inlet manifold today and still no better
Old Feb 10, 2006 | 04:46 PM
Im Amazed... sounded so mush like that problem...
You need to get her somewhere that can pressure test the system for you as it sounds 100% like you have a leak at peak boost.
When you say you removed te dump valve, you didnt just remove the pipe to te top of it did you? You took it OFF teh car and bunged up the big 25mm hole it left?
Old Feb 10, 2006 | 05:29 PM
vtr1981's Avatar
vtr1981
yes fully removed it from both ends and sealed them
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
