Is there an easy way to this......?
Old Feb 7, 2006 | 08:59 PM
DannyDK's Avatar
DannyDK
Default Is there an easy way to this......?
I want to check my head for cracks, do i realy have to take it off and send it to a head & bottom end company? Is there a way to check it without taken it of? Someone told me that if the water went back into the water container, then the head has a crack is that true??????
Old Feb 7, 2006 | 09:34 PM
DazC's Avatar
DazC
The only way to test for cracks is to remove the head and have it pressure tested at an engine remanufacturers....
The water always returns back to the header tank. It has to circulate to cool the engine..
Old Feb 7, 2006 | 09:41 PM
NUTS RuS's Avatar
NUTS RuS
X-ray it
Don't think its available on the NHS yet though
Old Feb 7, 2006 | 10:01 PM
DannyDK's Avatar
DannyDK
Better get it off then, it seems like it uses some oil and water, but not intirely sure about it though
Old Feb 7, 2006 | 10:07 PM
NUTS RuS's Avatar
NUTS RuS
Sounds like it just needs a new headgasket
Old Feb 7, 2006 | 10:09 PM
DannyDK's Avatar
DannyDK
Thats what i thought, so i ran out and got a new one, wich is fittet now, but it still smoke a bit and smells a bit funny from the zorst to....
Old Feb 7, 2006 | 10:27 PM
NUTS RuS's Avatar
NUTS RuS
Where did you put it ?
DazC's Avatar
DazC
CVH heads don't seem to be that prone to cracking to be honest but it's always worth checking to make sure. Just because they are not that prone to cracks doesn't mean to saythat it isn't cracked!
Old Feb 7, 2006 | 10:39 PM
DannyDK's Avatar
DannyDK
Somehow i hope its the turbo, its way easyer to change and cost about the same to get hold of
Mark RS
Oct 12, 2015 06:01 AM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
jc1989rs
Sep 18, 2015 07:05 PM
