What boost and possible power outputs?
in the next couple of weeks my car will have the following spec
cvh34cam
stage 1 head
stage 2 turbo
radtec frount mount cooler
what boost should this be set at, and would anybody reccomend running
a cossie fuel pump wtih this?
regards
mick
cvh34cam
stage 1 head
stage 2 turbo
regards
mick
Hi mate would advise getting a fuel pump think they
are about £130 from amber performance.
Its a good idea to get one just incase you get it chipped
in the future.
If the car is not chipped at the mo the standard ecu wont
let you run more than about 10psi of boost.
As for power id say around 185bhp ish that is a ball park figure
mate.
Cheers matt
in the future.
mate.
Cheers matt
i think the car is already chipped as it was making 190bhp
on motoscopes rollers(the most recent 1 anyway) on the old spec
std cam
stage 1 head
hitting 15psi
i think thats what the spec was aanyway.
the rolling road print outs show between 185 and 190(it seems to have been on a few times!)
av got all the printouts to show this
maybe it made that coz it woz done the monkey way, 15 psi
seems like a lot to me for the spec it had but i dont know much about engine tuning so my opinion counts for nowt!!!
i will defo fit the cossies fuel pump then
std cam
stage 1 head
hitting 15psi
I would mate you really dont want one of them dying and
taking the engine with it
When a S2 gets chipped a lot of tuners set the boost at 15psi
as this is around the safest for a farly standard engine
With those mods then fella i would say it would now make
around the 215bhp with a raise in boost not sure how much as different people set cars up differently. You will get a good rise in torque aswell.
Who are you gonna get to do the work?
Cheers matt.
Cheers matt.
Originally Posted by Matt J
I'd get the fueling seen to by Karl Norris or someone who knows the KE jetronic inside out, then you could run a decent amount of boost, supposing the engines in good health I'd guess at around 230bhp on that spec.
or even better, jamsport
i need all the info i can get
i live in the north east and there doesnt seem to be many people that know much bout tuning rs's up here.
unless anybody knows 1
the closer to newcastle or durham the better
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
