live mapping
Old Feb 5, 2006 | 08:57 PM
392B.H.P.SAFF's Avatar
392B.H.P.SAFF
Default live mapping
if u have your car live mapped do u have to have it checked
i had mine live mapped and the fans come on when u turned the iginition on now all of sudden they have reverted back to coming on when engine gets to hot
any ideas anyone have checked fuses and they r ok
Old Feb 6, 2006 | 06:49 PM
DazC's Avatar
DazC
What car? Does the ECU have any control over the cooling fans?
The cooling fans are not meant to come on when the engine is too hot, but to prevent the engine from getting too hot.
Old Feb 6, 2006 | 06:56 PM
392B.H.P.SAFF
daz c
the car is a saphire cosworth,Does the ECU have any control over the cooling fans tho that question i dont know but when car was mapped when i turned the iginition on the fans were coming on even when cold
now all of sudden they have reverted to coming on when the car reaches its temp
Old Feb 6, 2006 | 06:57 PM
Jamz's Avatar
Jamz
Why would you want the fans on when the engine is stone cold ?
Old Feb 6, 2006 | 07:01 PM
dannyblackpool's Avatar
dannyblackpool
Boost Builder
they have fixed a "fault" as it wasnt supposed to run on fan and would have thought it would affect mapping if engine wasnt up to temp
Old Feb 6, 2006 | 07:07 PM
big_wig_074's Avatar
big_wig_074
my saff ran the fans when warmed up,seems ur angry over a correctly running system!
Old Feb 6, 2006 | 07:10 PM
ballin's Avatar
ballin
exactly?!?!?! fans on from stone cold aint a good thing, u should be thankful
Old Feb 6, 2006 | 07:24 PM
392B.H.P.SAFF
all i know is i paid a lot of money for the live mapping and obviously dont want the expense of another rebuild so just checking
thanks guys
can the ecu fix a fault then?
so the map will still be ok
Old Feb 6, 2006 | 07:33 PM
DazC's Avatar
DazC
The Sapphire ECU will not control the cooling fans although the late cars with air con was tied into the management in some way...
I will also add that you can't map a car properly that isn't up to the correct operating temperature.
Old Feb 6, 2006 | 07:35 PM
xr4x4rs's Avatar
xr4x4rs
the ecu has no control over the fans
the fans are a seperate loom all together nothing to do with the mapping or anything else
did the fans use to come on when u turned igntion on when cold before mapping?
if they did then the people who mapped your car repaired the fault so they work normally as they should
you dont want your fans on all the time from cold either
Old Feb 7, 2006 | 09:00 AM
Stu @ M Developments's Avatar
PassionFords Creator
As all replies above....
Old Feb 7, 2006 | 09:11 AM
cossiecrew's Avatar
cossiecrew
who mapped it ?
JK12
33
Apr 26, 2021 12:09 PM
timsrs
Nov 13, 2018 11:48 AM
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
jay030787
Sep 25, 2015 01:38 AM
