Understeer.
Old Jul 21, 2004 | 10:59 PM
Alloy's Avatar
Alloy
Default Understeer.
What's the best way to over come understeer?
Old Jul 21, 2004 | 11:02 PM
Azrael's Avatar
Azrael
Learn to drive better
Old Jul 21, 2004 | 11:04 PM
FasterFords's Avatar
FasterFords
Buy some better tyres or slow down.
Old Jul 21, 2004 | 11:07 PM
EIL132's Avatar
EIL132
Default Re: Understeer.
Go RWD
Old Jul 21, 2004 | 11:26 PM
RSTurboPaul's Avatar
RSTurboPaul
Take your foot off the loud pedal
Old Jul 22, 2004 | 12:05 AM
richm's Avatar
richm
Go RWD
the only way worth worrying about
Old Jul 22, 2004 | 05:27 AM
dave cos4x4's Avatar
dave cos4x4
When you come to a bend,throw the arse around,no under steer then.
Dave.
Old Jul 22, 2004 | 10:16 AM
Alloy's Avatar
Alloy
What like a rally flick dave?
Old Jul 22, 2004 | 10:22 AM
Phil's Avatar
Phil
Jeebus
Buy a proper car!
Old Jul 22, 2004 | 10:26 AM
B19-TRB's Avatar
B19-TRB
rwd is the best way to do it as James said!
Old Jul 22, 2004 | 10:29 AM
Mike Gurney's Avatar
Mike Gurney
best way to reduce understeer is to increase the camber
or fit wider tyres to the front of the car
sometimes softening the rear of the car can help
what diff is in it
Old Jul 22, 2004 | 10:33 AM
SteveT's Avatar
SteveT
Yeah, go rear wheel drive!
But seriously,,,,
- decrease front tyre pressure
- increase rear tyre pressure
- increase front tyre width
- fit some better front tyres
- change front wheel camber
- softer front springs
- stronger rear springs
- change anti-roll bar. (thicker? thinner? dunno).
steve
Old Jul 22, 2004 | 11:03 AM
RichardPON's Avatar
RichardPON
To reduce FWD understeer, there are various options such as:
Decent diff for a start.
Stiffen up the rear end of the car/soften the front.
Increase the rear track slightly.
Tyre pressures, ARB stiffness etc etc..........
The old 205 rally car we had would outhandle most of the so called good handling cosworths on here..........
Old Jul 22, 2004 | 11:30 AM
Alloy's Avatar
Alloy
I guess i should have told you it's a Nitro powered RC car!
It's 4WD, so I could set it up to put a bigger percentage of power to the rears. I have been messing around with the anti-roll bar's and recently put thicker, stiffer ones on. I was also playing with the idea of hardening the rear suspension.
I'm sorry if this has annoyed anyone, I just forgot to say it was a RC car.
Any of you guy's into them?
Old Jul 22, 2004 | 11:45 AM
foreigneRS's Avatar
foreigneRS
Testing the future
that's funny.
Old Jul 22, 2004 | 12:37 PM
Alloy's Avatar
Alloy
I guess it is funny, I just hope it didn't piss anyone off though.
Old Jul 22, 2004 | 12:52 PM
Ryan's Avatar
Ryan
i think the seat at combe 2 weeks ago proved that FWD can be just as quick if not quicker than RWD.
its all in the suspension setup and tyres
Old Jul 22, 2004 | 01:55 PM
SteveT's Avatar
SteveT
Annoyed? LOL!
Well, I'd suggest you get some of that double sided selotape and wrap it around the front tyres. Should stop the understeer. for a bit.
steve
Lambchop
11
May 15, 2010 09:38 PM
saph in dorset
22
Aug 3, 2009 01:14 PM
42Haya
Feb 25, 2009 04:09 PM
Oranoco
Jul 24, 2008 04:25 PM
Chip
30
Jul 18, 2008 10:28 PM
