Cossie bits and bobs
Cossie Bailey oil breather in good condition £60 **SOLD**
Cossie ignition amp + heat soak gwo £20 **SOLD**
Cossie 2wd front calipers in gwo £70 the pair
Cossie 2 bar map sensor gwo £20
3 door parcel shelf vgc £100
Near new 2wd organic clutch done 150 miles cover and plate £50
Cossie 20mm alloy plenum spacer plate £35 *SOLD*
Bailey piston dump valve in blue (slightly faded) gwo £25
Collins blue anodised alloy -31 actuator off 2wd Cossie gwo £25 *SOLD*
Cossie Amal valve £10
2wd Cossie distributor gwo £30
3 door Cossie rear door cards vgc £35 each
Cossie 2wd rad fans complete and in gwo £35
Near new stainless coolant pipes X 2 for the bottom of the rad on 2wd Cossie £15 each **1 SOLD + 1 LEFT**
Tidy 2wd/3 door Cossie intercooler £30
L6 Cossie ecu (un-tested no chip) £50
2wd stainless needing minor repair to centre box think its a Mongoose with 3.5" rear pipe £80 collected.
3 door Cossie wheels in reasonable condition with 3 good tyres but no centre caps or locks £75 collected.
More stuff to be added later.
07718 901737
Cheers Spadge...
07718 901737
Cheers Spadge...
[quote="Davey8oy"]SPADGE
does the breather come with the fitting kit??
Nope sorry i was using braided hoses which have been used for something else
Cheers Spadge...
[/Nope sorry i was using braided hoses which have been used for something else
Cheers Spadge...
Originally Posted by Fiesta Ben
Its the exhaust an outwardly roll system?
Where are you to?
cheers ben
Where are you to?
cheers ben
Yes mate and i'm in Milton Keynes
Fordsportjay - the breather is sold sorry
I'll see what my bank balance is like and i'll get back to you on that
What size is the tail pipe?
Would you send it?
Would you send it?
The tail pipe yes
the rest no
Would you send it?
The tail pipe yes
the rest no
what if i pay postage?
Would you send it?
The tail pipe yes
the rest no
Have you ever tried packing an exhaust for shipment mate
I really don't have the time nor the inclination to do it fella sorry
Oct 9, 2015 07:38 PM
kosienutter
31
Aug 22, 2015 09:55 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
