feul pump
Old Feb 4, 2006 | 05:33 PM
PAT@SUPREMES's Avatar
PAT@SUPREMES
Default feul pump
was going to change my esc coz feul pump 2moro and noticed the part no. is different.i have got a bosch 044 fitted at the mo. but think it is playing up.i bought one the other week from atm and just noticed the part no. is 003.does anybody know what the difference is? cheers
Old Feb 4, 2006 | 05:51 PM
Damo V's Avatar
Damo V
Well apart from anuthing else.
the 044 is external and the 003 is internal, i.e. in tank
What did ATM charge you for the 003 item?
Old Feb 4, 2006 | 06:01 PM
PAT@SUPREMES
they charged me £100 .both pumps look the same. will the 003 work the same as the 044?. cheers 4 yr help
Old Feb 4, 2006 | 06:16 PM
Damo V's Avatar
Damo V
the 003 will be fine for greens etc..
Old Feb 4, 2006 | 07:35 PM
PAT@SUPREMES
im running 400bhp + with 340lbft on greys.the 044 pump i have fitted at the mo. is a in tank one.
Old Feb 4, 2006 | 07:49 PM
Damo V's Avatar
Damo V
I would fit an 023 But thats me..
Think you will find Bosch "044" pumps are external
Old Feb 4, 2006 | 07:59 PM
PAT@SUPREMES
cheers 4 yr help.i didnt want 2 fit the pump and have problems with it.ive only just got the car back on the road after having the head rebuilt.car spends more time of the road than it does on lol.
Old Feb 4, 2006 | 08:02 PM
Damo V's Avatar
Damo V
Originally Posted by PAT@SUPREMES
.car spends more time off the road than it does on lol.
Its a Ford
Old Feb 5, 2006 | 04:06 PM
M K's Avatar
M K
fitted the new pump & sender ect with pat today & all is good now
it was a 003 pump in there already so we replaced it with an 003 also a new sender while we was there so the gauge works properly now
Old Feb 5, 2006 | 09:59 PM
Simon Day's Avatar
Simon Day
Damo is right the 044 is external - I know because I bought one by mistake. go for the 023.
Old Feb 6, 2006 | 11:06 AM
SAM_COSWORTH's Avatar
SAM_COSWORTH
I put it on my escort somebody knows is it ok o I need another better than this?
Thanks for all
Old Feb 6, 2006 | 07:53 PM
Damo V's Avatar
Damo V
The fitting kit looks alright (though shouldnt the pump be a little lower?
BUT the actual pump??? Who knows IMA (Phil/boschman) will give you the specs on that
Old Feb 16, 2006 | 07:02 PM
Billabong's Avatar
Billabong
Just for info, on these uprated in-tank pumps, due to the fuel intake, it's even more important to fill back up with fuel when you reach a quarter of a tank, else under hard-ish cornering you could suck up a nice dollop of air.
Old Feb 16, 2006 | 07:41 PM
dave cos4x4's Avatar
dave cos4x4
noticed that on the track.
Old Feb 17, 2006 | 10:20 AM
SAM_COSWORTH
If somebody can give me the code finish of the pump 003 I need all numbers of the code to buy one like this
Old Feb 17, 2006 | 10:31 AM
Damo V's Avatar
Damo V
The Bosch 023 is better and that is
"B0580254023 "
Old Feb 17, 2006 | 01:07 PM
Malc50's Avatar
Malc50
Hi All
I have an uprated pump that was fitted by GGR, I have to fill up at just over half a tank on the gauge or it starts missing....
First time it did it I thought here we go thisis going to be expensive!!! But filled it up and fine...
Just a warning...
Malc
Old Feb 17, 2006 | 05:09 PM
SAM_COSWORTH
"B0580254023 "
Thanks a lot Damo, quickly I´ll buy a new one
Old Apr 24, 2006 | 05:33 PM
yrkesman's Avatar
yrkesman
I just contacted my local bosch dealer about these pumps and they told me that all of the bosch models can be mounted inside tank. The difference is just that some of them have internal filter and some of them don't. I have also heard that the 044 model has filter in the inlet side, so it could also be used intank pump as is.
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
A.t.p
Oct 23, 2015 07:54 PM
20/20 vision
Sep 29, 2015 11:27 AM
SMILER258
Sep 28, 2015 09:04 AM
