Fiesta's Other ! This section is for ALL types of Fiesta models that are (NON RS / ST) Such as ZETEC S /S16000 / METAL /TITANIUM / GHIA etc
Zetec help please
Old Mar 23, 2014 | 04:27 PM
Lee Reynolds's Avatar
Lee Reynolds
Default Zetec help please
Anyone give me an idea on this ?
I changed the water pump the other day on Lindsay's 1400 cc zetec se engined fiesta ! Went for a drive after all ok and it was fine the day after! Day after that she was doing a slow manoeuvre and had full lock on and says she heard a slight bang and its been miss firing and cutting out since ! I thought I bet alternator belt has snapped as I struggled with tension on it but when I got home and looked it hadn't ! Can't see anything obvious and know nothing about them!!! Sounds noisier too more tappety!
Old Mar 23, 2014 | 04:40 PM
gingerturbo's Avatar
gingerturbo
The annoying ginger guy
Check the core plugs next to the spark plugs. Does it run alright?
Old Mar 23, 2014 | 04:54 PM
Lee Reynolds
It runs over about 2k revs up to that its rough as hell and cuts out! Took plugs out and 3 and 4 were drenched in oil on the outside however ! Not sure if that's linked
Old Mar 23, 2014 | 05:45 PM
gingerturbo
Is it over heating as these have a cut off when they get too hot, the oil could just be the rocker gasket, and the bang could of bin trapped air? Does it smoke at all
Old Mar 23, 2014 | 05:57 PM
Lee Reynolds
No mate not overheating no smoke
Old Mar 23, 2014 | 06:09 PM
gingerturbo
Timing jumped a tooth?
Old Mar 23, 2014 | 06:14 PM
STeve's Avatar
Super Moderator
that was going to be my guess
Old Mar 23, 2014 | 06:23 PM
Lee Reynolds
It crossed my mind with the bang but the belt feels taught enough not to jump ! No timing marks ? So can't tell either !
Old Mar 23, 2014 | 06:24 PM
t230's Avatar
t230
check sump for debris first
Old Mar 23, 2014 | 06:26 PM
bigstinka's Avatar
bigstinka
Had similar symptoms on my 1.4 focus and it was the temp sender between plugs 2-3 unplug it and see if it's any better.
Old Mar 23, 2014 | 06:30 PM
gingerturbo
They only have a auto tensioner on these engines and there common to jumping, and on full lock its under a load so could of jumped, there easy to check as all you need is a locking pin and a straight flat bar
Old Mar 23, 2014 | 06:40 PM
Lee Reynolds
Can you elabourate on that mate please?
mk3ste
Oct 17, 2021 10:09 AM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
SMILER258
Sep 28, 2015 09:04 AM
mondeomark
Sep 28, 2015 06:28 AM
focuspower
Sep 20, 2015 03:51 AM
