Fiesta's Other ! This section is for ALL types of Fiesta models that are (NON RS / ST) Such as ZETEC S /S16000 / METAL /TITANIUM / GHIA etc
Fiesta starting problems - won't turn over
Old Mar 20, 2013 | 08:04 PM
ross_jsy's Avatar
ross_jsy
Default Fiesta starting problems - won't turn over
Hey guys,
Signed up here as I'm in need of a bit of help for a friends car I am repairing. I'm a BMW guy myself so need a bit of guidance!
It's a 2001 Fiesta 1.25. My friend managed to crash it but the car started up fine after the crash. Since then I repaired the damage to the A-arm etc. Took a couple weeks to get the bits and during that time the battery died so replaced it with a brand new one as it was on it's way out.
Now the car won't start at all. Won't even crank over. There are no clicking sounds at all when the key is turned fully. All the dash lights up just as it should. Checked all the fuses, swapped the starter relay out and checked the cut off switch in the passenger foot well; all good.
I'll be going round tomorrow with a multimeter to check the starter is getting a 12v feed and the solenoid is getting one as well.
Is there anything else I should be checking or is a common problem?
The airbag went off and hasn't been replaced yet, but since it was running fine after the crash I doubt that's the problem. Also there is so flashing light coming from the immobilizer.
Many thanks in advance,
Ross
Old Mar 20, 2013 | 08:11 PM
RichieST's Avatar
RichieST
red light should flash once every few seconds with ignition off, turn ignition on and it should come on solid, then go out after 10 seconds or so. Have you made sure all the wires are back on the battery?
Old Mar 20, 2013 | 08:13 PM
ross_jsy's Avatar
ross_jsy
No flashing at all, in fact he seems to remember it never flashing.
Yep, everything is back how it should be
Old Mar 20, 2013 | 08:18 PM
RichieST's Avatar
RichieST
I'd be checking fuses etc, might be possible that it had a spike or something. Did you jump start it by any chance? Not too sure if these have smart charge as if it does you should never jum start them as it can kill various ECU's etc.
Old Mar 20, 2013 | 08:20 PM
ross_jsy's Avatar
ross_jsy
Checked literally every fuse (both central and under bonnet fuse boxes) and all the relays, including the ones behind the central fuse box to no avail. Didn't try and jump start it but these don't have smart charge as far as I know
Old Mar 20, 2013 | 09:45 PM
gingerturbo's Avatar
gingerturbo
The annoying ginger guy
When you say crashed how bad, also did you check all the earths as a feature in the bodywork will weaken any earth point
Old Mar 20, 2013 | 09:50 PM
ross_jsy's Avatar
ross_jsy
Not overly bad. In fact I was very surprised that the airbag deployed.
I'll give them all a good check tomorrow, unfortunately light was dying fast last time I was up so didn't get to look at much
The Underdog
29
Sep 7, 2015 09:49 PM
Bailes1992
Aug 16, 2015 07:14 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
muz
Aug 1, 2015 06:48 AM
