Fiesta's Other ! This section is for ALL types of Fiesta models that are (NON RS / ST) Such as ZETEC S /S16000 / METAL /TITANIUM / GHIA etc
Fiesta tdci 1.6 problem
Old Jan 18, 2013 | 09:46 PM
paul-h's Avatar
paul-h
Default Fiesta tdci 1.6 problem
Ok so the problem is a squeak at idle, been to the dealer and they put a new fan belt on it apparently. Anyhow, squeak still there. I've since saw on the ZSOC forum that a guy had his water pump replaced and that solved his squeak.
Now what do I have to say to them to get them to investigate the water pump as I live around 120 miles from the dealer and work away so it's not as simple as just popping in and out every day or two.
Anyone on here had experience with this or know much about it?
Car is a 59 plate Zetec S with 25,000 on the clock
Cheers, Paul
Old Jan 18, 2013 | 10:45 PM
matthewpickup's Avatar
matthewpickup
just say you read that there was another car with the noise and it was the water pump that was the problem but maybe better to call first?
Old Jan 18, 2013 | 10:51 PM
paul-h's Avatar
paul-h
I'll phone in the morning but I'm already pissed off with them!!
Old Jan 19, 2013 | 01:18 PM
stboy's Avatar
stboy
Water pumps do squeek on them however changing the pump doesn't always fix it. Its a known issue with ford not yet sure if they have solved this issue. One at my old work had Four pumps fitted! Solved it for a few weeks then it came back. Worth contacting Ford about it
Old Jan 19, 2013 | 01:41 PM
kevin lancelott's Avatar
kevin lancelott
No I got same engine as you same reg and only 5000 less but mine is ok.
Old Jan 19, 2013 | 05:41 PM
MikeyRobbo's Avatar
MikeyRobbo
PS3 - MikeyRobbo
Avoidddd these engines at all costs!! Shittest engine Ford have ever put in a car!
Old Jan 19, 2013 | 08:23 PM
paul-h's Avatar
paul-h
Yeah I'd like to speak to a DECENT ford tech but I just can't bring myself to trust them?
So basically I'm fingered as some of these cars do it and some don't?
What's the other common issues with these engines then folks?
Old Jan 19, 2013 | 08:26 PM
matthewpickup
wish i could help as that is shit , hope you manage to get things sorted
Old Jan 19, 2013 | 08:59 PM
Cossie Sean's Avatar
Cossie Sean
big floppy donkey dick
common problems? lol
lubrication problems that destroy turbos,
for the warranty on a new turbo:
new injector seals/refurb`d injectors
remove sump and replace oil pump
clean oil galleries throughout engine
replace oil filter
replace turbocharger and all oil pipework
EGR issues
wiring issues
ECU issues
and waterpumps just like like this one
other than that the Pug engine is a good little unit
Old Jan 19, 2013 | 11:02 PM
paul-h's Avatar
paul-h
Haha, happy days! And with my luck I am destined to get all of the above!!
Fuck a duck!!
Old Jan 20, 2013 | 08:52 PM
matts zetec s tdci's Avatar
matts zetec s tdci
i had a squeak, had new water pump ,cambelt ,and a crankshaft pulley that seemed to work .pulley was Ł124.74 cambelt was Ł118.71 and waterpump was Ł97.08 plus the labour this was all done a a ford dealer.mines a 55 plate 1.6tdci. hope this helps mate.
Old Jan 25, 2013 | 08:14 AM
paul-h's Avatar
paul-h
Thanks for this mate, I just don't like how the techs at ford have to be spoken to through someone, I'll speak to them and see if I can get them informed of this water pump malarkey!
Old Jan 25, 2013 | 05:01 PM
matts zetec s tdci
hope you sort it out mate
JoeyBoyden
Jan 4, 2024 02:36 PM
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
da52rkn
Ford Focus Range
Aug 21, 2015 04:41 PM
