Fiesta's Other ! This section is for ALL types of Fiesta models that are (NON RS / ST) Such as ZETEC S /S16000 / METAL /TITANIUM / GHIA etc
Ford techs help!
Old Dec 17, 2013 | 08:03 PM
James B's Avatar
James B
Default Ford techs help!
My girlfriends mk6 fiesta has developed a loud twanging like a spring uncoiling when turning from lock to lock.
I crawled underneath the best I could with a torch but it's too low (standard) to get underneath properly.
The only unusual (to me) thing I can see is what looks and feels like a rubber tube dangling down the inside of the drivers front spring and can't see or feel one on the passengers side. But I don't know if that's normal or not at all..?
It hasn't done this ever before and I used it today on a 50 mile round trip and it hadn't done it then and just now we went to go out in it and it started. It reverberates around the car it's a loud twang!
Old Dec 17, 2013 | 08:05 PM
St3V3_C's Avatar
St3V3_C
Spring snapped a coil off I would say.
Old Dec 17, 2013 | 08:09 PM
James B's Avatar
James B
Forgot to add I cant hear anything if I bounce all my weight over either wing
Old Dec 17, 2013 | 08:40 PM
James B's Avatar
James B
Just got it home put my work clothes back on managed to get under it.
You was correct Steve, what I thought was rubber tube is the very top flat coil, snapped off and stuck around the shock inside the rest of the spring.
What sorta job is this? My dad has changed springs before so it just a case of stripping the whole strut down getting the fucked coil off and getting a new one on the strut?
Old Dec 17, 2013 | 08:44 PM
Cossie Sean's Avatar
Cossie Sean
big floppy donkey dick
the top mounts will need changed,
you will find the shock top nut is ful of water and rotten!!
so shocks, springs and top mounts usually
Old Dec 17, 2013 | 08:53 PM
James B's Avatar
James B
It's only the drivers side as far as I can see but that's not what I wanted to hear lol
Old Dec 17, 2013 | 08:55 PM
escort4x4's Avatar
escort4x4
U dnt need to change top mounts or strut. Only change them if it's damaged. Just change the spring. Ull soon see if damage has occurred when u fit the spring. If ur unsure. I run a workshop in dagenham. Pop it in n I'll inspect it for u
Old Dec 17, 2013 | 09:04 PM
James B's Avatar
James B
http://bit.ly/1keCLMS
Are they what I need? It's not lowered or anything just a standard car.
Old Dec 17, 2013 | 09:09 PM
Cossie Sean
i see about 5 fiestas a week with rotten strut nuts/thread where water has sat for years rotting it away
if the allen key is fucked in the centre how you gonna get the nut off??
mole grips and an air gun?
nice!!
Old Dec 17, 2013 | 09:13 PM
escort4x4's Avatar
escort4x4
Lucky I have a stock of nylon locking nuts. Heat it up then whizz them off. I see many many fiestas aswell and can say that I dnt see rotten strut nuts. So opinions vary. Also I'd like to meet ur customers lol. Come in for snapped springs n u spank them for shocks which work perfect n perfectly fine top mounts. Quality business lol.
Cossie Sean
as you can see on this one, its soaking wet
they fill up with water
even this one is rotten
Old Dec 17, 2013 | 09:14 PM
Cossie Sean
heat it up and whizz them off??
listen, crack on lad
no more replys from me.
Old Dec 17, 2013 | 09:16 PM
Cossie Sean
just read it again,
where do you heat them up as the top mount is plastic you fuckwit!
pointless replying
escort4x4's Avatar
escort4x4
Yeh heat them up. Not to melting point. Amazing when you try it. The only trouble I've had is on the ford galaxy's as they do get soaked and do rott. Never had trouble with fiestas.
I've never had to replace everything lol
Old Dec 17, 2013 | 09:17 PM
Cossie Sean
excelent
Old Dec 17, 2013 | 09:20 PM
James B's Avatar
James B
Pic won't load bud. So can't reply with a comparison.
No need to argue over it fellas obv everyone has no doubt seen all sorts of crap on cars
GVK.'s Avatar
GVK.
Great design, the rain tray drains the water straight into the OSF top mount.
Great advice heating a shock absorber up.
But as they say, each to their own.
Old Dec 17, 2013 | 09:21 PM
escort4x4's Avatar
escort4x4
Im not arguing lol. Just voicing an opinion which he has different views on. Each to there own. But I'd personally advise only replace what's needed. I very much doubt top mount n shock will need to be replaced
Heating the nut will not harm anything. Obviously not to melt the nut. Just heat the nut enuff to release it
Old Dec 17, 2013 | 09:23 PM
James B's Avatar
James B
Great.
Old Dec 17, 2013 | 09:36 PM
saph4be's Avatar
saph4be
nice!!
Fully agree lowered a mk6 other week and the threads for shocker were that rotten the nut would not re tighten so ended up with a pair off shocks!
Old Dec 17, 2013 | 09:43 PM
James B's Avatar
James B
Any ideas on prices guys? Or best sites to look?
Old Dec 17, 2013 | 10:19 PM
James B's Avatar
James B
http://www.eurocarparts.com/mobile/e...c5c7349&000925
Same for the other side.
http://www.eurocarparts.com/mobile/e...ac192fa&000073
Anything else req? Top mounts, nuts etc?
Old Dec 18, 2013 | 02:57 PM
James B's Avatar
James B
Bump bump
Old Dec 19, 2013 | 04:05 PM
James B's Avatar
James B
For once silence isnt golden, any advice on where to purchase?
Old Dec 19, 2013 | 05:38 PM
Matt478's Avatar
Matt478
I changed same spring on a mates fiests ST. That had done the same.
He got the spring from the local motor factors.
Also got new pinch bolt for lower arm, nut for steering rod end and a new nut for the end of the driveshaft.
Easy enough job to do with basic tools and spring compressors.
Old Dec 19, 2013 | 06:19 PM
dojj's Avatar
dojj
Resident Wrestling Legend
if you do change anything it's normally best practice to change them in axle sets as you don't want one side new and the other side being fucked
when the spring snapped on my mondeo it broke the top mount as well so not that i'm saying it's got to be done, but at £12 a side, is it worth leaving alone and then needing to get the tracking all sorted once you've put it all back together again?
Old Dec 19, 2013 | 06:40 PM
Matt478's Avatar
Matt478
'While its in bits, i might as well change this too"
Old Dec 19, 2013 | 06:52 PM
James B's Avatar
James B
Originally Posted by Matt478
I changed same spring on a mates fiesta ST. That had done the same.
Yeah I saw in the Haynes manual that it suggested replacing a bunch of nuts, particularly any under a fair bit of torque
Will deffo be changing per axle bud, seems its quite cheap to buy it all in pairs Ive noticed. Thanks for the heads up tho on the top mounts!
Ive not had the chance to have a look at it since it shat itself its just sat parked up coz of work. Shit time of the year for it to happen though as I bet it will be a nightmare trying to find motor factors open now..
Old Dec 19, 2013 | 07:21 PM
Cossie Sean
fill the galley on the strut top up with WD40 for a few days and let it soak, keep topping it up
this will help
Old Dec 19, 2013 | 07:24 PM
GVK.'s Avatar
GVK.
Just to add, the lower pinch bolt that secures the shock into the hub, if it's tight, get some heat on it. If it snaps in the hub you're in a whole world of pain.
(Yes,yes I know I said don't heat up the shock, but you're not going to really, just the hub/knuckle)
Old Dec 19, 2013 | 07:37 PM
James B's Avatar
James B
Haha! Thanks for the heads up. Will a little gas bottle one do the trick? Dont have anything bigger..
..or a Zippo..
Old Dec 19, 2013 | 08:12 PM
Cossie Sean
as per PM,
either but EVERYTHING new, Strut, spring and strut top
OR (rather than "spanking you" as previously said )
buy a complete used item and bolt it on!
no need to disturb the dreaded top nut
and about £40 a side used and gets you on the road
Old Dec 19, 2013 | 09:03 PM
James B's Avatar
James B
as per PM,
Using euro car parts I found 2 x springs for £26 odd each, and front left and front right shocks for £46-47 odd each but they havent got top mounts in stock but saw some genuine ford ones on ebay for £20 each so £200 would give me everything i need?
Old Dec 22, 2013 | 06:11 PM
James B's Avatar
James B
So I had a crack at this today.. was all going well, had the strut out of the hub and clear of all the wheel arch. Put the allen key into the top of the shock and was turning the nut around whilst holding the middle still with the allen key then it just span, when i looked close up it had crack down the thread so the allen key just span in the hole as there was no longer any pressure on it.
So, ive got 2 new shocks reserved for tomorrow morning and going to pick up 2 new strut tops too. eurocarparts have got 25% off shocks atm so can get both for £70. Got the springs for £18 + vat from GSF car parts in West Thurrock.
Billy_RS
16
Oct 11, 2025 09:41 PM
borboyous
Aug 22, 2015 11:17 AM
Bailes1992
Aug 16, 2015 07:14 PM
