Fiesta's Other ! This section is for ALL types of Fiesta models that are (NON RS / ST) Such as ZETEC S /S16000 / METAL /TITANIUM / GHIA etc
MK5 Rear Axle / Adding ABS
Old Aug 28, 2013 | 09:56 PM
Bryan93's Avatar
Bryan93
Default MK5 Rear Axle / Adding ABS
The rear axle on my Fiesta MK5 has taken a beating, and its bent. So im going to have to buy another one for the car. Iv seen a rear axle for sale, but it has ABS fitted. My car does not have abs and im not sure if i can still fit and use it like the old one. Although if i can, im considering maybe getting ABS fitted, if it meant i could use it.
Could I get ABS fitted to a car that originally didn't have it. ?
And/Or, could I just use it without the ABS ?
Thanks for any help provided. Cheers.
Old Aug 28, 2013 | 11:00 PM
Cossie Sean's Avatar
Cossie Sean
big floppy donkey dick
you will be fine to remove the drums/backplates from the new axle and use your old ones
stub axles are all the same so you can keep them.
fit some Poly bushes while its out
Old Aug 28, 2013 | 11:12 PM
Bryan93's Avatar
Bryan93
So i cant just fit the handbrake cable to the new axle with abs drums ?
rex647
Mar 6, 2022 06:20 AM
jessie_rs
62
Aug 6, 2019 09:27 PM
DPDISXR4Ti
Ford Fiesta
Sep 21, 2015 03:51 PM
Tony W
Sep 9, 2015 12:08 PM
cossirob
Sep 3, 2015 09:17 PM
