Fiesta's Other ! This section is for ALL types of Fiesta models that are (NON RS / ST) Such as ZETEC S /S16000 / METAL /TITANIUM / GHIA etc
Zetec over heating, HELP PLEASE
Old Feb 25, 2013 | 03:13 PM
rsdan123's Avatar
rsdan123
Default Zetec over heating, HELP PLEASE
Hi everyone, I have a mk 6 fiesta 2006 1.6 zetec s and it over heating!
I have had a look today and....
Top water hose is boiling and bottom is freezing!
Heating inside car is cold and gauge on dash reads normal but header tank is bubbling hot!
Done a sniffer test and a compression test that both come back fine!
I have taken the thermostat out and checked that it opened ok!
Do you think it's a water pump???
Danny
Old Feb 25, 2013 | 08:17 PM
rsdan123's Avatar
rsdan123
Anyone???
Does anyone know if the water pumps are known for breaking on the zetec se engines?
Are the propellers on the water pump metal or plastic???
Thanks for you help
Danny
Old Feb 25, 2013 | 08:22 PM
Cossie Sean's Avatar
Cossie Sean
big floppy donkey dick
on the late ones the waterpump holds the timing belt tensioner so you need to do a belt kit aswell
if you took the stat out and its still boiling over id have a look at the waterpump, although they are metal impellors
Old Feb 25, 2013 | 08:23 PM
Secret-Turbo's Avatar
Secret-Turbo
Might help might not...
...... but i have a mk5 zetec s, and a few weeks back it started overheating too,... turns out it was the top hose , so replaced that and hasnt done it since . Could be that
Old Feb 25, 2013 | 08:38 PM
Mr.T's Avatar
Mr.T
flush the system. Maybe its blocked?
Old Feb 25, 2013 | 08:39 PM
Mr.T's Avatar
Mr.T
have to say...had the boiling thing on my old 2.0 dohc sierra once. It had a cracked head
Old Mar 4, 2013 | 06:58 PM
rsdan123's Avatar
rsdan123
Little update (still need help)
Had the water pump off today... They are plastic, but its fine!
I'm really baffled now!.... Had a few people suggest head gasket but I'm not convinced + I've done a sniffer test & compression test that both came back fine!
What else could it be?
Danny
Old Mar 4, 2013 | 07:43 PM
Cossie Sean
thermostat? blocked rad? blocked matrix?
process of elimination am afraid fella
Old Mar 4, 2013 | 07:45 PM
Cossie Sean
ooooooooooooooooooh also, one thing to check that ive came accross a couple of times
on the back of the head, theres a small pipe that comes out of the head (g/box side)
the aluminium 90degree pipe currodes and blocks solid with currosion and shyte, make sure the pipe is free and the hole in the head is too!
this is the "bleed pipe" that returns water/air to the tip of the header tank
Old Mar 4, 2013 | 08:03 PM
gingerturbo's Avatar
gingerturbo
The annoying ginger guy
I've had a load of these with the similar issue, its normally the stat or expansion bottle check the bottle for creasing or cracks, and check the stat, also I've had a few with cracked heads, does it cut out and go into limp mode
mk3ste
Oct 17, 2021 10:09 AM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
mondeomark
Sep 28, 2015 06:28 AM
