Fiesta's Other ! This section is for ALL types of Fiesta models that are (NON RS / ST) Such as ZETEC S /S16000 / METAL /TITANIUM / GHIA etc
1.7 puma conversion
Old Jul 29, 2011 | 03:39 PM
blackrstdean's Avatar
blackrstdean
Default 1.7 puma conversion
hi guys i own a zetec s 2001 and i want to put a puma lump in it wot other parts do i need to
change apart from the engine of course??????
thanks.
Old Oct 9, 2011 | 09:21 PM
gosa264's Avatar
gosa264
Hi mate im looking to do the same in the future, puma speed can fit one for you, ive stuck the link up for you, http://www.pumaspeed.co.uk/product-1...fitted_256.jsp or if you want to do it yourself they would proberly be best to ask for advice
Old Nov 2, 2011 | 06:28 PM
sheeks's Avatar
sheeks
u will need the following.
puma lump, ecu preferably a tape one as its easier to fit(only 2 wires to join up then)
key and transponder for the engine to start. (u just swap the transponder into your old fiesta key then.
drivers side top engine mount
puma airbox .
puma throttle cable and u will also have to join some new fuel lines up as the connectors are different .
apart from that ts a straight swap. just use the standard zs driveshafts and exhaust system as they all fit.
Old Nov 2, 2011 | 06:56 PM
Chip's Avatar
Chip
*** Sierra RS Custard ***
Michael Woodford Motorsport do puma conversions pretty cheap, PM tank mike on here about it.
Old Nov 23, 2011 | 03:02 PM
joshc's Avatar
joshc
Ive been trying read up about the loom? Some have said u just need.the loom in the engine bay then some have said about snipping 4 wires inside the car.going to the fuel pump or rear abs? Im totally confused on what i need to get i need to.get the ecu key etc also so if therea an easier way off a certainecu than another could someone please help! Lol
Old Nov 23, 2011 | 03:24 PM
Chip's Avatar
Chip
PM Tank_mike on here mate, im sure he'll help you out with some info, he must have done 50+ of these conversions now.
Old Nov 23, 2011 | 05:31 PM
joshc's Avatar
joshc
so if i unplug all the plugs sensors and the fusebox and ecu il be left with one long loom that goes into the bulkhead thru to passanger footwell where i have to cut 4 wires?
Old Nov 23, 2011 | 05:51 PM
sheeks's Avatar
sheeks
you dont cut any wires, remove the fuel pump wiring, u will need to remove the interior trim for this, pull that right up and out the car along with the cars wiring loom to the engine, along with the ecu. pull all this out through the bulkhead , then its a straight swap back through the car like you took out, (only wire u have to maybe join in the car is the black earth wire if u cut it as it a pain to get into the bolt.) then 2 wire in the fuse box in the engine bay .
Old Nov 23, 2011 | 05:52 PM
sheeks's Avatar
sheeks
what ecu are you using , u might need to change the pins on it for the temperature gauge to work. ?
Old Nov 23, 2011 | 05:57 PM
sheeks's Avatar
sheeks
Size:  152.9 KB all that wiring pull the whole lot out the car.
Old Dec 22, 2011 | 09:32 AM
big baird's Avatar
big baird
i know off people that do a good job and for less money
Old Apr 19, 2013 | 06:30 PM
Bperry89's Avatar
Bperry89
Default Help?!?!
Hi mate when you say pins what pins?
If you could get back to me as my head is very confused at the minute! Thanks ben.
Old Apr 19, 2013 | 06:31 PM
Bperry89's Avatar
Bperry89
Default Help?!?!
Hi when you say pins what pins? Realy need help as my head is all over the place! Thanks, ben
Old Apr 21, 2013 | 03:33 PM
Straight_4_N/a's Avatar
Straight_4_N/a
easyer just to swap the fiesta internal loom for a puma one.
Old Apr 22, 2013 | 10:30 AM
Bperry89's Avatar
Bperry89
Nah. Thats long...
Old Apr 22, 2013 | 01:31 PM
Straight_4_N/a
once you take the dash out it takes less than 5 mins to swap them over.
Old Apr 22, 2013 | 02:45 PM
lacey's Avatar
lacey
I done this conversion on my Zetec s .
I has a whole car to strip from which was lucky, I used a analogue loom , which made it had work as I had to swop everything , then the rear end need rewiring as all plugs where different there where some otherthings that I had to swop , by using the whole loom you lose your fog lamps , so I rewired them in with the high beam .
But I you use the digital loom you only need the wiring under the bonnet ( plus the odd wire in the car ) but then it is as good as plug and go , if I remember right
You need
Engine ( of course lol)
Dig" engine loom
Air flow meter
Ecu
Keys
That what I found out after the convertion , also if you don't use dig" car loom then you need to change the fuel level sender as a full tank will read empty , and reversing the wires don't work , and the sender was not a direct fit in the tank , but I think the puma tank may fit , but I didn't try it ( I should have )
Old Apr 22, 2013 | 03:26 PM
denis's Avatar
denis
Originally Posted by Bperry89
Nah. Thats long...
lazy bastard
Old Apr 22, 2013 | 03:35 PM
Bperry89's Avatar
Bperry89
Lol mate if u knew the problems i had before the engin converted. No need to talk like that.
Old Apr 22, 2013 | 03:59 PM
denis's Avatar
denis
i couldn't care less what problems you have had, stop being a lazy bastard and do it properly
Old Apr 22, 2013 | 04:10 PM
sidewaysdave's Avatar
sidewaysdave
I'm doing this as we speak I just bought a complete puma and I've pulled the engine bay loom out only thing you don't have is fog light wiring. Join zsoc as there's a step by step guide on there, also fast ford done a guide a couple of months ago which is very good as well every body tells different story's so best just to get on and do it!
Old Apr 22, 2013 | 04:17 PM
Bperry89's Avatar
Bperry89
Didnt ask for ure opinion mate (denis)
Old Apr 22, 2013 | 04:18 PM
Bperry89's Avatar
Bperry89
Thanks sidewaysdave much appreciated ill do that
Old Apr 22, 2013 | 10:01 PM
denis's Avatar
denis
you're*
and its a public forum, whether you ask for it or not you will get peoples opinions, so either get used to it or don't use forums
Old Apr 22, 2013 | 11:59 PM
Straight_4_N/a
Originally Posted by lacey
You need
Dig" engine loom
Air flow meter
Ecu
Keys
you have to change alot more than that.
engine
intake manifold
brake sevo pipe
fuel lines (if yours are rubber)
left hand engine mount bracket
Old Apr 23, 2013 | 12:08 AM
Straight_4_N/a
engine bay loom
throttle cable (agin it depends)
ecu plus chip to match
maff
air box
intake pipe
its 99% plug and play but there internal loom anit a dircet match to the engine bay loom so you have two choice. either replace internal loom and rewire tails (but much easy just to duck tape the puma bulb holders in place) or relocate the ecu wires so your rev light temp gauge and fuel pump works.
Old Apr 23, 2013 | 12:14 AM
Straight_4_N/a
THIS IS A MUST!!!! the rubber fuel lines have the wrong conectors to clamp onto the pumas fuel rail and thay will look like thay but dont and it will cause them to leak.
the rubber connectors holes are to small to go over the bump in the rail thats designed to keep them on.
Old Apr 23, 2013 | 12:18 AM
Straight_4_N/a
also the puma eninge loom is in two parts one with the fuse box and headlight looms etc but the second part is very short and only has iirc 3 plugs on it and if you dont have your engine will never start. oh and the injector wiring to lol that makes 3 parts lol
Old Apr 23, 2013 | 09:55 AM
Bperry89's Avatar
Bperry89
Thanks chaps. My car starts its driveable its just the bloddy temp gauge!!grrr it was a project car before i got hold of it nuffin wrong with it watsoever just the face the temp gauge doesnt work, yeah i change the flow in the tank that workd..
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
mk3ste
Oct 17, 2021 10:09 AM
SMILER258
Sep 28, 2015 09:04 AM
youngben
Sep 27, 2015 09:37 PM
Marv888
Sep 26, 2015 03:44 PM
