Fiesta's Other ! This section is for ALL types of Fiesta models that are (NON RS / ST) Such as ZETEC S /S16000 / METAL /TITANIUM / GHIA etc
Fiesta Mk5 brake/ABS problem
Old Feb 7, 2011 | 03:38 PM
Wrig's Avatar
Wrig
Default Fiesta Mk5 brake/ABS problem
a few strange things happened with my brakes over the last 2 weeks, first the abs light came on every now and then and it still does this. the the brakes would make kind of a clicking noise and you could feel them going on and off (or what i thought was the abs going on and off). i had a search around and it sounded like the abs ring had gone.
a few days later a weird clicking/tapping noise came from the back passengers wheel sounds like there was something stuck to it had a check and couldnt see anything. this noise lasted 2 days then went away.
now today the handbrake light stays on and the brakes hardly work theres no pressure and it feels like u have put ur foot on and off them, like pumping them up.
anyone had this before to this extereme?
Old Feb 7, 2011 | 04:08 PM
Dal_'s Avatar
Dal_
Does it sound like this?
http://www.youtube.com/watch?v=oRyIKg9yANE
If it does, your rear ABS rings are knackered. Happened to me as the ABS sensor had taken off the tops of the sensor when a wheel bearing failed.
Old Feb 7, 2011 | 04:17 PM
Wrig's Avatar
Wrig
yes thats what was happening.......... im guessing now they have completly gone and thats why the hand brake light is constantly on and theres basicly no brakes.
any idea where i can get new abs rings from cant seem to find them on the net or should i just nip to ford.
thanks for that
Old Feb 7, 2011 | 04:20 PM
Dal_'s Avatar
Dal_
I got mine from Ford when I needed them. About Ł20 a pair or something IIRC. Check your wheel bearing and sensor as well. The rear sensors are a Y split pair connected in the middle of the rear beam.
Old Feb 7, 2011 | 04:36 PM
Wrig's Avatar
Wrig
ill have a check over them tomorow see whats going on.
Old Feb 8, 2011 | 03:00 PM
Wrig's Avatar
Wrig
had a check on it today took the wheel off, and now i know why my breaks have gone. its leaking break fluid. ive orderd the abs ring already from justchanged my orderd to the wheel drum 62 quid bit gutted but its needed.
Old Feb 8, 2011 | 03:31 PM
Dal_'s Avatar
Dal_
If the rings still have a pronounced curve, then they'll be ok I'd have thought. If your ABS sensor is covered in crud from your leaking cylinder, then that'd give you the same symptoms I expect.
I've got some pictures of a new and knackered one.. I'll upload them and post them up..
Old Feb 8, 2011 | 03:39 PM
Dal_'s Avatar
Dal_
New one:
Knackered one:
Old Feb 8, 2011 | 03:52 PM
Wrig's Avatar
Wrig
i wouldnt be suprised if its both with the luck im having at the moment.
thanks for the pictures big help ill let you know how i get on.
Old Feb 12, 2011 | 09:41 AM
Wrig's Avatar
Wrig
brakes fixed, in the end it was the rear wheel cylinder leaking and a clip missing, the brakes were all squw wift because it wasnt there.
abs ring was fine, brakes are great now. thanks for your help
Old Apr 5, 2011 | 10:21 AM
RY4N-H0850N's Avatar
RY4N-H0850N
Did you not need to replace your ABS rings in the end then? Mine look like the ring in the second picture (knackered) and have had the noise since I had the car. Is this surely what the problem is? Both wheel bearings are fine.
Old Apr 21, 2011 | 12:17 AM
RY4N-H0850N
Bump... Can I ask what clip was missing? Having the same problem. Do you have a picture or know what the clip is called please? Thanks
rex647
Mar 6, 2022 06:20 AM
Marino
Sep 12, 2015 11:10 AM
28
Sep 8, 2015 07:10 PM
routemaster
Sep 7, 2015 05:27 PM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
