power cable
power cable
how do i run a power cable from my battery 2my boot on my fiesta mk3 1.6 si as i cant see any where 2put the wire through on my old saxo there was a big grommet to put it through i could really do with some help 2day plz peeps as i need 2get my vibe sub in and running by tuesday as im off on a roadtrip 2 cornwall cheers in advance simo
Remove the washer bottle and there is a dirty great grommet some 3-4" in size where the wiring goes into the car. Make a small hole in that and pull it through (make sure it's tight as you don't want any water finding a way in.
Only downside to this is it does mean a more lengthy cable run but at least you're not drilling anything
just remember to seal the hole up properly - i made a new hole behind where the ecu is as i am relocating the battery in the boot
are you blind man as oranoco says, there a huge rubber grommet on the left hand side (as your standing at the front facing the engine) where ALL the engine loom goes into the car
cant miss it really
cant miss it really
muz
30-09-2015 08:29 AM
