Brake PROBLEM
Old Aug 25, 2005 | 10:02 PM
motherhupit's Avatar
motherhupit
Default Brake PROBLEM
Just finished taking all the alloys of my mk3 fiesta to regrease the bearings. put the whole lot back to geather and don't seem to have any brakes the pedal sinks to the floor untill you pump it a few times. and it stifens up.
All i did was reset the rear automatic brake adjusters, and push the front pistons back into the calipers about 1 mm. brakes will lock up if you pump it and then hit the brakes. but don't work that well. and if you don't pump the brakes the pedal sinks to the floor and slows down very slowly and the pedal also does'nt seem to rise back very fast.
It has ABS. and i had to hammer a hub to try and get it off i wouldn't have damaged 1 of the valves. or something. i can't seem to see any leaks either. PLEASE HELP. need to fix Before WESTON.
yatta
May 21, 2016 10:31 PM
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
focus2351
Sep 9, 2015 09:33 PM
routemaster
Sep 7, 2015 05:27 PM
cossirob
Sep 3, 2015 09:17 PM
