rs1800 turbo , what do i need ?????
what du i need to do to my engine to put a turbo on it ????
and were can i get the parts i need ??
ps i live in norway
ps i live in norway
turbo radiator & intercooler
fiesta rs engine management
turbo and manifold
if you dont want to touch your engine, you might be able 2 get away with running 5psi ish. if you want more, youd probably have 2 fit a decompression plate
turbo and manifold
ON THE ROAD AGAIN
have a look at zetec-turbo.co.uk these guys are zetec turbo masters
rough guide u will need
d-comp plate ( i would run even a plate what ever boost m8 could save u in long run)
rad
intercooler(of choice if budget build frst)
frst fuel rail+injectors
frst ecu (ofab or ofac)
frst eging bay wiring loom+sensors
turbo/manifold(u can use focus rs 1 but limitations to turbos- or get head drilled+tapted for erst manifold)
custom exhaust +f/p
oil feed for turbo(t peice from oil press switch)
oil seperator(for braethers)
the rest is drilling and tapping or alloy welding u need 1or 2 breathers in crank case
2 oil returns to sump(1 for oil seperator other for turbo return
and other small bits heres few picts of my build,tommy
just abot done
hope this helps m8 give me a shout if u need any help,tommy
rad
custom exhaust +f/p
just abot done
JK12
33
26-04-2021 12:09 PM
