wanted ofac ecu
wanted ofac ecu
Im after an ofac ecu as have a running fault with a fiesta rst i have just aquired. The problem is it runs 0.1%co and cant ritchen it up. There are no air leaks, mixture potentiometer has been replaced so has ecu tempo sender and map sensor. All wires have been checked can only the last resort or the fuel pressure reg? any other ideas
A little bit of rewiring will need to be done, see http://www.fiestaturbo.com/phpBB/viewtopic.php?t=77331
Originally Posted by tim10_10
is that the only difference? will the map sensor plug be the same? if so how much im pissin in the wind with this one so dont want to spend a fortune!
Price? I dunno, £100 posted?
big_Rad
15-09-2017 09:36 AM
