FRST Coilover fitting help
Old May 12, 2014 | 03:17 PM
JK12's Avatar
JK12
Default FRST Coilover fitting help
Hey!
Tried putting my new GAZ coilovers on today but had major trouble!
Put the shocks on, had to make a spacer so they didnt move left to right, but thats sorted.
Anyway When i put the wheel on and try to lower suspension to a suitable height the adjuster hits the wheel so i cannot lower it anymore.
Looks like i need a spacer and longer studs so the wheel misses them.
What size spacers and where do i get the longer studs from?
Not even tried the fronts yet
i have 3 door cossie wheels - anyone else had this problem??
Old May 12, 2014 | 03:53 PM
Maxwell's Avatar
Maxwell
Irregular Poster
Sounds like you have mk3.5 fiesta suspension and hubs in your car.
Regarding longer studs, get mk1 mondeo ones. They fit perfectly and 5mm longer than frst ones. Though would 5mm spacers help you out?
Old May 12, 2014 | 04:30 PM
JK12's Avatar
JK12
Hi thanks for the reply mate!
How do you tell if it 3.5 set up on it?
I've already got 5mm spacers on her
Old May 12, 2014 | 05:31 PM
Maxwell's Avatar
Maxwell
Irregular Poster
Well you said that you put the coilovers into the hubs and had to make a spacer so they didnt move about. Mk3.5 fiestas having larger diameter shocks and hubs would lead me to believe thats what you are running and im assuming you done your homework and made sure the GAZ coilies came out of a frst. So if the coilies are 100% correct and they rattled inside the hubs, then your initial set up was from a mk3.5.
Regarding wheel spacers, i cant help. My frst was running fk coilies and also 5mm spacers and mondeo mk1 studs, and my 8 x 16" oz mags didnt buff at all.
Old May 12, 2014 | 05:44 PM
JK12's Avatar
JK12
Must be 3.5 rear bean then
The gaz coilovers are brand new made to order so know they are for mk3.
What's the differences on the beams out of interest?
Cheers for help mate
Old May 12, 2014 | 05:53 PM
Maxwell's Avatar
Maxwell
Irregular Poster
Oh its just the rear is giving bother??? Sorry i thought the fronts where.
Regarding the beam are you sure it isnt a mk5 fiesta beam?? But even at that im near sure the rear shocks are the same from mk3-5.
Old May 12, 2014 | 05:59 PM
JK12's Avatar
JK12
Not even tried the fronts yet lol
Thought the rear would be easy!
I've sorted the issue with a spacer to stop the play which my mate fitting them sorted. So you think the mk1 Mondeo studs are longer?
Old May 12, 2014 | 06:21 PM
Maxwell's Avatar
Maxwell
Irregular Poster
Yeah i read about the mod on the rsoc. Bought one and campared it to a stock frst one and true bill it was 5mm longer, so i test fit it and all was good, so i bought the other 15 afterwards.
So your rear shocks are floating from passenger side to drivers side?? Is there not supposed to be a built in spacer in the shock?? Have you measured the diameter of the fronts incase they did send you an incorrect set?
Old May 12, 2014 | 06:38 PM
JK12's Avatar
JK12
Where the bottom of the shocks connect at the rear to the hub it's has play left and right so the shocks can slide, the 2mm spacers holds it tight!
Def mk3 coilovers so must be a different beam, how do you tell?
I will order some longer studs and go from there now!
Thanks again mate
Old May 12, 2014 | 06:41 PM
Maxwell's Avatar
Maxwell
Irregular Poster
Frsjon on here will tell you better what the differences are in the axles. If you look through fiestaturbo, it will explain too.
Old May 12, 2014 | 06:42 PM
JK12's Avatar
JK12
Will have a nose! Found a few longer stud conversion on the bay
Cheers mate ��
JoeyBoyden
Jan 4, 2024 02:36 PM
bigryrs
Sep 5, 2015 02:57 PM
bigryrs
Aug 28, 2015 05:32 PM
saph in dorset
Aug 14, 2015 10:10 AM
track.focus'd
Aug 12, 2015 05:53 PM
