please help!
cheers for any advice. peach.
I would do as you say ther largest intercooler with a alloy rad, but also put in a swirl pot, and plumb this to the expansion tank via the TOP smaller pipe to act as a degas, as cooked water forms air.
Look at blockin in the air flow of the radiator, so you get no side spill of air, as air will take the eaisest route, it will go around a object(radiator) if it is easier.
Fit some bonnet vents.
thanks for the advice had not initially considered the swirlpot route. am going with a full width alloy rad so that i shouldnt have to worry about air running around the side of the rad with a twin fan setup. and bonnet lifters for the hinges to let out more hot air. will get the swirl pot setup sorted and hope fully ill be able to be in traffic for more than 5 minutes again.
cheers again.
cheers again.
sound good, i've got a grs rad(standered size) and grs front mount intercooler with one 10" kenlowe fan with a adjustable thermostat which works very well, temp needle goes up to the N on NORM very pleased with it
