Help please RST wont start
Got my recon turbo back this morning and spent this afternoon fitting it. Come to start the car, and it wont start.
Turn the key. ignitions on but it wont start. I have checked all the wiring and its wired as it was before i removed the turbo.
Currently the black blue wire is on to the starter with the battery cable and the blue wire is on the solenoid. On ignition theres 9.2v on the blue but it doesnt change when you go to crank. Should this top up to 12v on cranking. If so where does the wiring run to or does anyone have any other ideas please why it wont go.
![Mad](https://passionford.com/forum/images/smilies/mad.gif)
Originally Posted by m4dyeti
Check you didnt knock the crank position sensor of which sits just above the starter motor in the block
does the engine crank over if not give the stater a wack with a hammer. Wiring sounds ok problery should be a bit higher voltage but should be enough to get it cranking. Whats the voltage at the battery???
Well its running,
the numpty who had the car before me cut most of the loom up and just twisted them back together. Spent all day soldering and tidying the loom up.
Why do they do it
. If in doubt leave it the F*@k alone......
Why do they do it
JK12
33
26-04-2021 12:09 PM
andrewmctiernan
08-09-2015 03:05 PM
