MK II fiesta
MK II fiesta
Hi I don't know much about fiestas, so maybe you can help.
Were MKII fiestas fitted with CVH engines? I wonder is it lighter then MKIII/IV escort? and would the RST engine fit without any modifications?
I know the MK2 XR2 was fitted with a CVH. It's much lighter than an escort and the engine will fit in with a few modifications.
The engine itself should go straight in but you will have to do mods for intercooler, etc.
rst engine will go in but you need to cut a piece out the front x-member to clear the downpipe, wiring loom needs the esrt engine loom splicing into it, you need a swirl pot for the fuel tank.
Originally Posted by XR2
Looks like there are people all over the world that like the MK2
My escort after all I did to it weighs somewhere in the region of 800 kilos.
What is the weight of MK2 fiesta? Maybe MK3 has the same weight too?
MK3 Fiesta has nearly got the same weight as the MK4 Escort. My XR2 is weighting at 840 kg according to papers
P.S. Eine coole seite du hast da und deine fieste siet fantastisch aus
Originally Posted by Maki
My escort in papers is 970 kg, so maybe it's worth swaping?
Thanks!
I wonder now what driveshafts people use as they swap those engines? RST ones (do they fit), or standard fiesta ones?
Found one XR2 down here for reasonable price, so can't sleep now
XR2 and diesel driveshafts were thicker than the standard ones on the MK2. Buy that XR2, it's also got the engine lowering and the bigger brakes.
I hope you'll find another one. They're rare these days unless you live in the UK and want one with the steering wheel on the wrong side
But it's worth to fit better Brakes than the 1.1's
maybe you might check out www.xrtwo.com
You can find many hints on this forum how to upgrade MK2 brakes and engine!
found this site...
http://www.retrofiesta.co.uk/
there is in information section turbo power guide... Please someone tell me what is true and what is not about fiiting the ERST engine into MK2... I think it's more about MK1, so not sure what do I have to look at. For example do I have to make any cutting to the wing for the ERTS gerbox? are'nt MK2 XR2 gearbox cases the same as escort ones? then why there is a need to cut anything?
Steve Escos
01-10-2015 06:57 AM
