blowing off the rocker cap???
can any1 shed any light on why i keep blowing off my oil filler cap, what could be wrong, how can i fix it.
Thanks in advance
Matt
Thanks in advance
Matt
It could be crankcase compression (worn rings) but as you have a new engine try a new cap the rubber seal go's in the inside try the new type with the grub screw
Strip and clean out your breather system before worrying about serious issues. And buy a NEW oil cap as the rubber seals in them go shitty after a time.
Could also be ring blow by pressurising the crankcase, but do the above first before worrying about that.
Originally Posted by Mr Shannon
Get a rocker cover with a screw on cap instead
have a look at the breater pipe at the back of the block, its usually to do with a bit of crank case pressure, or maybe think about a breather system, tend to work better then the stock ford system
take the breather filer/pot off and replace it, your problem will be there more than likly.
but dont bin the old one, i may want it
07-10-2015 12:56 PM
deathrider666
28-09-2015 06:12 PM
SMILER258
28-09-2015 09:04 AM
