How Hard Would It Be...........
To put a Mondeo 2 litre lump into an XR2i which has had a CVH in it all of it's life?
What would I need to swap over, what would I need to buy?
Would I need a Cat for the MOT?
I know this sort of thing has been done before but from what I can gather it has been done with the 1800 zetec models?
Any help much appreciated
You will need the engine loom and ECU for the 2.0 as well as the correct engine mounts. Not sure but you may find the radiator is different between the CVH and Zetec cars
You won't need a CAT for the MOT.
Originally Posted by Wardy257
You will need to use a 1.8 ZETEC waterpump too.
Originally Posted by Oranoco
Not sure to be honest mate did it when he went Zetec turbo on his FRST so I'll ask him when I see him next
Ok, change of plan. The engine I've got isn't that great after all. Plus can't be arsed
Ok, another question, what would I need to turbo it?
Other than:
Turbo + Manifold
ECU
Other than:
Turbo + Manifold
ECU
All the elctrics although your loom can be modded to work with a couple of pin swaps iirc.
Fuel pump, tank injectors, head and cam are all the same as the FRST items. You will need to change the cam pulley as the FRST item is slightly more retarded.
You'll need the bottom end, rad, fan, intercooler, exhaust, turbo etc. While you've got it in bits you might as well T3 it as the T2 is a big bucket of arse and not capable of anything to write home about.
The Youth.
30-09-2015 09:59 PM
SMILER258
28-09-2015 09:04 AM
