clutch slave cylinder replacement - tips?
Testing the future
anyone replaced a clutch slave cylinder on a mk4 fiesta 1.25 and can share any tips?
mine went on friday 13th
got waynes manual and everything that tells you how to remove gearbox etc, but there's often a better way, or a little trick that you can use or something
Testing the future
dave green thanks dave. i know that i have to remove the gearbox. that is for certain, as it's a concentric jobber that pushes the release bearing so has to come off the gearbox input shaft.
just wondered if there's some tricks or helpful hints in removing the 'box that aren't mentioned in the waynes manual
NC53
13-09-2015 03:05 PM
Si B
12-09-2015 06:49 AM
